Deleted member 6817
- Thread starter
- #1
I have my Lariat's version of the non asbuilt page fully populated into a spreadsheet. See the Forscan GUI tabHi
Am hoping someone has a link to, or photos/videos of the non AS Built modules, Ive made changes and lost where they saved to, I maded 2 profiles and it either doesnt load them, or they're both the same, but its thrown an orange esc warning, and pre collision assist warning and now its locked in park.
Anyway, Id need to see standard NON AS Built menu's of the BdyCM, IPMA and APIM modules to be able to change all mine back to standard, its going to take weeks for ford to sort it, and its obviously not covered by warranty, so Id prefer to get it sorted before Im up for a huge bill.
Thanks
I believe you have to have either saved your factory config, or have access to it on the web. It doesn't automaticly populate. If you click it , it will ask you where it is, or if you want to look for it.Doesnt Forscan now have a way to revert built in?? Thought under IPC Module Configuration asbuilt at the bottom it has a tab to "Load Factory AB", or does that only work on older trucks?
How did you get everything back to factory asbuilt?I just wanted to check it against my back ups, and poasibly upload the standard one as mine didn't appear to load.
All errors are cleared, its back to standard, but car is still locked in park.
Anyone had shifter interlock issues? How did you fix them? Quoted $2k to replace the solenoid and it comes with a new shifter, I dont need a new shifter or 2k bill so any help would be appreciated.
