+15 offset 285 fitment?
exia
TRD Off-Road Premium
Well-known member
los angeles
24 tacoma hybrid Trd OR
Hi everyone,
I have te37xt 17inch +15. I am trying to pair them with 285/70/17 ko3. One shop said they would fit another said I needed a lift.
Will they or will they not fit ?
I think th shop saying I needed a lift is wrong but I wanna get feedback.
Thank you for the help in advance.
SilverSurfer
Well-known member
California
Tacoma TRD OR Premium Plus
That’s a wider tire with an offset pushing the tire outwards. It could rub at full turn or under turn and compression. I’m doing 275\70\18 and it barely fits. I’ll pop your settings into a figment calculator and see if your settings are wider than mine.
SilverSurfer
Well-known member
California
I guessed your rim at 8.5 wide. With that, your tire is 4% wider than mine, which barely fits.
I’d be cautious before going all in on that tire Size and get a test fit, first.
2024 Tacoma +15 offset 285 fitment? IMG_0114
hemlockz
Well-known member
PNW
ā€˜24 TRD Offroad 6MT
I’m that size tire with +20 and no lift, it’s got lots of extra room from what I can see
Lex16
SR5
Eder
Goodyear, Az
2024 Tacoma sr5
They fit but remove the rear bracket might help a bit incase it does rub. I ran it fine stock shocks
exia
exia
Well-known member
los angeles
Without removal of the bracket on your build ?
SilverSurfer
Well-known member
California
Also there’s variations between manufacturers on tires of the same size, so check that out too if it’s really close.
exia
exia
Well-known member
los angeles
That’s what I was thinking to I’ll ask if I can test them. Before buying it I appreciate the assist
exia
exia
Well-known member
los angeles
Thank you to those that helped I have attached photos and confirm 285/70/17 +15 offset works.
2024 Tacoma +15 offset 285 fitment? IMG_1217
2024 Tacoma +15 offset 285 fitment? IMG_1218
