Sorry, I thought that was somehow included in that size. They're 11.6" wide and 34.1" overall diameter. Item 2884-7839 https://www.falkentire.com/wildpeak/at4w#size-listWe need to know the wheel width. Without it offset doesn’t matter.
What size is the wheel? 17x?Sorry, I thought that was somehow included in that size. They're 11.6" wide and 34.1" overall diameter. Item 2884-7839 https://www.falkentire.com/wildpeak/at4w#size-list
I'm happy to help but I need the width of the rim not the tire size.Here's a good response that has me hopeful https://4runner6g.com/threads/34-ti...with-no-lift-level-or-trimming.784/#post-2630
The 285/75R17 Falken Wildpeak A/T4W translates to a 34.1-inch diameter and an 11.2-inch width. That tire will fit, especially with a +30mm offset. You will have a little poke, but nothing too aggressive at all.
You might be able to get away with just removing the mud flaps in the front and maybe removing a crash plate in the wheel well for the wheel to fully lock forward and reverse.
You shouldn't have a problem with that tire. I don't foresee trimming of the front bumper or sheet metal at all, though.
ooooh Gotcha. I'm newbie lol.I'm happy to help but I need the width of the rim not the tire size.
You’re welcome. They will be in towards the body 9mm (.345”) more than this. These are 285/75r17 Yokohama Geolamder MTs 17x7.5 et15. No lift.Thanks! Fingers crossed. I'll post updates
8.5” may rub on the inside. I can’t tell you if they will work or not. But the will poke a bit on the front.@carpartsclemons Can I do 265/70R17 with 17x8.5 +25 offset wheels without rubbing and no lift? Thank you in advance
Looking at Icon wheels, they only have +25 offset wheels that has a 95.1 center bore size. If I go with 265/70R17 with 17x8.5 +35 offset with stock suspension/no lift, will it still rub at full lock?8.5” may rub on the inside. I can’t tell you if they will work or not. But the will poke a bit on the front.
17x8.5 et35 will for easier than 17x8.5 et25. Et35 will sit inboard 10mm. The more poke the harder it is to fit without rubbing (how much depends on each car).Looking at Icon wheels, they only have +25 offset wheels that has a 95.1 center bore size. If I go with 265/70R17 with 17x8.5 +35 offset with stock suspension/no lift, will it still rub at full lock?
Thank you17x8.5 et35 will for easier than 17x7.5 et25. Et35 will sit inboard 10mm. The more poke the harder it is to fit without rubbing (how much depends on each car).
