Gastan
TRD Pro
Well-known member
Mark
Oregon
Tacoma TRD Pro
I posted this in another thread and thought it'd be a good resource to post in its own thread for future reference.
If your 2025 4Runner doesn't come with Tow Tech Package factory installed, then it won't have a wiring harness to connect the OEM Toyota controller to under the dash. Tacoma and 4Runner owners have found that there's no way to retrofit install the OEM brake controller. Even Toyota dealerships don't have a solution to add the OEM brake controller. That leaves aftermarket trailer brake controller as the only option.
AFTERMARKET (PHYSICAL BRAKE CONTROLLER)
I've seen Tacoma owners installing Redarc trailer brake controller though, so there's aftermarket solutions at least. I've attached a couple of great installation guides for Redarc Electric Brake Controller posted by Tacoma owners:
Aftermarket Trailer Brake Install Guide #1
https://www.4runner6g.com/forum/att...tallation-for-2025-4runner-6th-gen-docx.7117/
Aftermarket Trailer Brake Install Guide #2
https://www.4runner6g.com/forum/att...instructrions-2025-4runner-6th-gen-docx.7118/
Here's what Redarc brake controller switch looks like installed in blank dash location.
2025 Toyota 4runner Aftermarket Trailer Brake Controller -- DIY how-to install instructions -trailer-brake-controller-2025-4runner-6th-gen-
AFTERMARKET (WIRELESS BRAKE CONTROLLER)
See wireless options info : https://www.4runner6g.com/forum/threads/wireless-trailer-brake-controller-options.2522/
olefriend
Well-known member
TX
Supra A90, 2025 4Runner TRD ORP
Excellent info and install DIY writeups thanks for putting that together. That's a shame though about the lack of a harness to connect OEM brake trail controller if you don't order the tow package.
Parker516
TRD Off-Road
Well-known member
Parker
Old Westbury - NY
Incoming TRD OR
Seems like Toyota coulda made it much easier for owners if they just included the harness anyway even if your 4Runner didn't come with tow package. I assume this was a bean counter decision?
Mrknowitall
Active member
SE MI
Crosstrek, Silverado
I have the Redarc Liberty in my Silverado. Had to buy the generic pigtail and wire it to the pigtail that came with the truck- careful- red and black are backwards.
works like a champ.
kinetic262
TRD Off-Road Premium
Active member
PA
2025 4Runner
I installed a redarc break controller on my 5th gen 4Runner and it was a snap. It came from redarc with the wiring harness that I needed. It took me about 90 minutes from start to finish to install. Somebody with more knowhow probably could've done it in 45 minutes. Happy to have a built in unit on my new 6th gen though.
tustmeimlying
TRD Off-Road
Prescott
2025 4runner OR
If my 4runner has the tow/haul mode selector as well as the 7pin and 4pin connectors at the trailer hitch, it safe to assume I have the tow package or is there other components I am missing to use the OEM trailer brake controller
tustmeimlying
TRD Off-Road
Prescott
2025 4runner OR
The conclusion from that thread seems to be "I don't know, buy a tekonsha", or am I missing something lol
rfdj
SR5
Mark
Kansas City
'25 SR5 4Runner 3-row
That the plug for a brake controller is there and it works and wired correctly. All major brands that made stuff for the '24 should work with the '25. Cause it worked with mine. There was a doubt that the '25 that didnt have the tow package had the harness to connect to.
