Best value trim models for 2025 4Runner 6th gen (by use case)
Gastan
TRD Pro
Well-known member
Mark
Oregon
Tacoma TRD Pro
I'm curious what everyone thinks is the best value trim for each of the following use cases:
On-Road Use Only
- for me: TRD Sport​
Mix of On-road & Off-road Use
- for me: TRD Off-Road​
Heavy Off-Road / Overlanding Rig Use
- for me: Trailhunter​
MJE
Well-known member
Calgary, AB
2022 Ford Bronco Sport
My use case is primarily on road. Off-road for me would be unmaintained roads you could take a Subaru down. I can agree with either of your choices in on/off road.
The TRD Sport seems to give you most of what you’d need & the 360 cameras are available on the premium version. What I can’t recall though is which trims have the 3rd row & which are hybrid. That to me might be the ultimate deciding factor. No 3rd row & hybrid for me.
But then I’m probably also shopping closer to LC levels (& will compare the two) so I’m probably between Limited/Platinum. Both of which might be the best choice for me, but probably aren’t at the top of the list when it comes to ā€˜value’ trims.
DustyLens
TRD Off-Road Premium
Well-known member
Dusty
Phoenix,AZ
2010 4Runner SR5
I would consider only the hybrid. If you don't want the hybrid, then stick with a 5th generation. Why get a gas-only 6th generation, at least before they've been out a few years?
I mostly commute in my 4Runner (and it's a very short commute), but I like the ability to do some fairly serious off-roading here in Arizona and SoCal.
So I'm looking into a hybrid TRD Off-Road Premium, in green, with moonroof.
AlanA
SR5
Alan A
Roseville, CA
2005 Tacoma
What about the regular gas version?
andim
Well-known member
Boston
2015 Cherokee Trailhawk
Trailhunter for light off roading and light overlanding. I could go with a TRD off road and build it up a bit. But then the price difference to the trailhunter is only ~5-7k . And since I'm not the do it yourself car mechanic type I think it's in the long run much cheaper to have the Trailhunter with all mods already done and under warranty.
I know it's a bit lame but I think there will be three types that buy a Trailhunter: People with money who just love the looks. People like me who do light off-roading and don't have the time, space, tools and skill to build up a TRD off-road. And people who plan on more serious offloading/overlanding and build up the trailhunter.
qtb007
Well-known member
Quentin
Hurricane, WV
23 GR Corolla
While the SDM not being available on the TRD OR is surprising, a VAST majority of 4Runners don't have KDSS. I bet it is on the order of 1 in 20 or less. When I bought my '16 trail edition, I had to search far and wide to find one with KDSS. It wasn't a game changer, IMO. It drove nice on the roads but it was a heavy system and limited armor options because it hung down lower than the standard suspension.
IMO, the Sasquatch is going to be a completely different animal than a 4Runner. It is a true off road bruiser. That said, the 4Runner is pretty darn capable for what most people are doing with them and is a significantly better daily driver. If I were you, I'd jump on a Limited with 3rd row and toss an aftermarket suspension under it with some 33" all terrains and have a real jack of all trades vehicle on your hands. It won't be as good off road as the Bronco, but it will be a much better vehicle 95% of the time with a great full time 4WD system and excellent technology. And it will probably get 20% better fuel efficiency than the Bronco.
Regarding the OP's original question, I'm currently between 4Runners. I've had 3 different 5th gens ('10 SR5, '16 Trail, '23 Pro) and around 130k miles between the 3 of them. The last one was a company car, so it went back since the 2 year lease was up. I'm trying out the 4Runner-less life for the time being but watching intently to see how things play out. If I had to buy one today, I'd probably go with a TRD Off Road Premium, non-hybrid because I don't need the extra power and the extra 6 cu ft would be nice. The Pro isn't exactly in the same strata as the Pro that I had. It's moved up market considerably. I think that the 6th gen TRD OR will be a hair more capable than the 5th gen Pro while having a ton of tech that the 5th gen doesn't. After driving a bright orange 4Runner around for 2 years, I think I'm ok blending in a little bit, too.
