Check engine issues with 2024 Tacoma -- Valve Air Issue (another connector issue)
Drm919
Well-known member
NC
2022 Toyota Tacoma SR5
Go check out the unrestricted channel
Valve air issues 😞
bking
Well-known member
Bernie
Ohio
2021 F150
Just saw this as well. I wonder if this is the result of the QC holds.
I think the guy plugging in these connectors was on the sauce for a few weeks. Could very well be the hold. Also wondering if some stupid production line problem at the factory could've broken the 4wd for TFL. Loose bolt, no cotter pin on the axel shaft that allowed too much play in the system.
beninbeta
Well-known member
Ben
Colorado Springs, CO
Hyundai Tucson
Do we know if the ones with these documented check engine lights/connector issues are all from the same factory or is it both?
Kielly
Well-known member
Ryan
Alberta, Canada
2024 Tacoma Sport+ 6M
Someone posted on YouTube with another system malfunction error throwing codes up on his dash. My bet is on the already notorious plug connector for the shutters. Any guess'?
If I'm correct, maybe this will be the first ever recall 😬
JBSwine
Well-known member
2022 Kia Sorento
This one has already been posted. Seems different that the grill shutter issue. Who knows....could even be loose gas cap.
