Coolant level?
Cyder
Nick
Buffalo
I was filling my windshield washer fluid and noticedthe coolant level in my RR is below the minimum line. I take it in on 9/30 for an oil change and tuner install but just curious if this is normal? Should I fill with coolant before taking it to the dealer?
Edit: After more research, looks like this is normal based on the engine being cold. I’ll check again after it’s hot as it should expand and be above the line.
Ford Ranger Coolant level? IMG_6804
Deleted member 9086
Use distilled or demineralized water to bring it up to full. That’s all that needs to be dome.???
Deleted member 11408
Thanks for this. Filled up my windshield wiper fluid and noticed the same thing. Engine is cold. I’ll have to check on it later after running some
