CATOY
Well-known member
NorCal
2024 Tacoma Off Road Premium and 2007 Sequioa LTD
Here are the measurements for the storage compartment (if equipped) , keep in mind that the top and bottom depths are not the same. The cover measurements also shouldn't be used as there's a ridge it sits on unless you plan on cutting the box out.
Let me know if you require more precise measurements and I can great a jig to fit in there.
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5916
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5917
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5918
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5919
Here are some more pictures with the box removed. The last couple are measurements of the edges of the unit.
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5926
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5927
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5928
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5929
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5930
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5931
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5933
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5935
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5936
Blue Crush Taco
Well-known member
Dare
Ontario, Canada
2024 Tacoma Sport
Good to note, the Sport+ 6M Canadian build DOES NOT have these compartments. Disappointed when I seen that last
8A Sport Plus Canadian doesnt get the storage box as well. I may add it though in the future. Looks like easy enough to do......
CATOY
CATOY
Well-known member
NorCal
I agree, you could probably install one pretty easy using nutserts as long as you don't mind cutting into the bed. Don't forget to check the other side to make sure that there are no wires back there.
Blue Crush Taco
Well-known member
Dare
Ontario, Canada
2024 Tacoma Sport
Haha. Ya good point. Would be just my luck that the main can-bus runs there or something stupid- lol . I think you can look up there from the bottom. I'll have a look before I get the Sawzall
CATOY
CATOY
Well-known member
NorCal
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5940
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5941
2024 Tacoma Dimensions: Storage Compartment on passenger side of bed (measurements) IMG_5942
CATOY
CATOY
Well-known member
NorCal
The picture of the connector is the back side of the AC outlet.
