TacoFish
Trailhunter
Active member
Bill
Snoqualmie, WA
2024 Trailhunter Bronze Oxide 6' Bed, 2023 Audi Q4 etron
Question - seems simple enough but maybe I'm missing something... to turn on the inverter the truck has to be started, correct?
I know the engine cycles on/off but when you start the truck you have everything inside (HVAC, HUD, display, etc) on...
So in order to power something from the bed, is it essentially necessary to start the truck, turn a bunch of stuff off, turn the inverter on, and then basically wait for the engine to cycle off and on as needed?
The only time I can get the "AC 120V" switch to light up and then have power at the the outlet in my bed is when the engine is running. As soon as I turn off the engine, the "AC 120V" light switch goes off and the power is off at the outlet. In page 454 of the owners manual, it does call out that the hybrid system must be running in order for the power outlets to be used.
I really wish I could use the power outlet without the engine running, just pulling from the hybrid batteries.
trailhunger
trailhunger
Trailhunter
Well-known member
2024 TH
It's a closed system, and the inverter does often run exclusively off the hybrid battery - at times. All depends on the 120V load you're pulling, the state of charge on the hybrid (have you been rallying the truck using the NiMH for additional HP when driving or running the air conditioner a bunch, etc. If you're pulling a couple hundred watts, the engine can stay off for ~12+mins. All depends on what other electronics are running on the vehicle too. The hybrid system ALWAYS will keep the NiMH at a high topped-off SOC. If that hybrid battery is ever drained...according to the maual...requires a tow to the dealership
DeadSetMonkey
Trailhunter
Well-known member
Denver, CO
Toyota GR86, Rivian R1S, Vanagon Syncro Westy
Ok. So. I need spoon fed.
For 120V access from bed of my Trailhunter, I must have ignition on (not just ACC) and the dashboard 120V inverted switch toggled on.
The engine will then kick on/off to top off battery pending 120V draw.
I can sit parked. With key fob I can lock the vehicle. I can be driving.
Do I have this right?
myrr
Well-known member
WA
24 Trailhunter
Think so - that’s the way I understand it as well
DeadSetMonkey
Trailhunter
Well-known member
Denver, CO
Related question re: power access in truck bed.
My truck as the power/compressor in back.
From where does the compressor and the USB/ciggy power port pull power?
Does this power source behave like the inverter: i.e. engine will fire up to prevent battery depletion if something plugged into the 12V DC power port?
OR will a constant draw on that power source ultimately deplete the battery?
