Instrument Cluster Set Up (Changes On Its Own)
dvolman93
Well-known member
CA
2024 Toyota Tacoma
Has anyone noticed when setting up a page on the dash that if you have the tire pressure “widget” as an option that the next time you go to turn on the truck it goes way to either the next “widget” or it’s just blank?
CATOY
Well-known member
NorCal
2024 Tacoma Off Road Premium and 2007 Sequioa LTD
I have also seen that too. I’m trying to figure out if it’s one specific tab or if it depends on what you select. I have one tab with tire pressures and boost and that stays as is, the next tab is current trip and MPG and that also stays and the third tab is trip A and Trip B. When I change the tab with the tire pressure to show the wheel slip, that also changes. It’s when I try to select the temperature settings that it changes. Are you trying to set the temperatures?
dvolman93
dvolman93
Well-known member
CA
2024 Toyota Tacoma
No. On one tab I have the Average MPG and the tire pressure. But when I turn the truck off for a while and go back to turn it on the tire pressure goes away and it shows the compass.
CATOY
Well-known member
NorCal
I haven’t read the manual yet for those screens, just been trying to figure it out on my own. I’m have seen strange behavior after cycling the power like you claim. I think it will even let you select the same two items for each side which a good programmer would skip that as a selection if you already had it on one side and you weee trying to set the other. I wonder if number one is dedicated or something dumb like that.
CATOY
Well-known member
NorCal
Here’s another weird one where it flips the distance and total time depending on which trip you have selected.
2024 Tacoma Instrument Cluster Set Up (Changes On Its Own) IMG_5658
dvolman93
dvolman93
Well-known member
CA
2024 Toyota Tacoma
I just put the same thing on screen 1 and 3 to test out your theory if maybe it’s only certain screens. I tried to look in the manual but no mentions of what I was looking for.
Planoman
Well-known member
DFW, Texas
2024 Tacoma Off Road Premium- Silver
Yes, initially I thought it was because I did not have the TPMS set at 30 PSI. I did that and the pressure gauge still does not stay. It may be because it is activated when you drive and the pressure are displayed when there is a reading and not overnight when it may deactivate?
GRKTRD
Well-known member
Nick
PHX
24 Tacoma
I also have quite a bit of infotainment system glitches and delays to turn on sometimes I wonder if it even is going to turn on takes that long lol
CATOY
Well-known member
NorCal
My screen 1 options on the left side were changed again this morning. This looks to be a bug. It’s only happening to screen 1 options for me. I swapped the two screen one options this morning to see if the left side changes again. I always have boost on the right and it stays while the tire pressures on the left change to something else. This is how I left it this morning. The active breaking was also acting a little weird for a while on one of my trips this morning.
2024 Tacoma Instrument Cluster Set Up (Changes On Its Own) IMG_5680
dvolman93
dvolman93
Well-known member
CA
2024 Toyota Tacoma
Truck seems to have some bugs. I’m sure once more people make some noise about Toyota will push out an update.
CATOY
Well-known member
NorCal
There was also a feature in the app he first couple weeks that showed you how you were driving and I can’t seem to find that anywhere now. It showed you exactly what location you hit the gas or brakes too hard. Would have been handy when you take your car in for service as I know lots of Corvette owners have seen their cars abused when they took them in for services.
dvolman93
dvolman93
Well-known member
CA
2024 Toyota Tacoma
I did see they updated the app but I never looked at that
bking
Well-known member
Bernie
Ohio
2021 F150
Can you set it up so it only shows the speedometer and fuel? That's all I really want to see most of the time.
