It looks like SLATE has pathetic EV efficiency. (and a rant).
AZFox
Arizona
Vehicles
Honda NC700X
Or take the tailgate off and run a net instead.
It doesn't work the way you'd expect.
AI query:
Does lowering (opening) the tailgate of a pickup truck improve its coefficient of drag?​
Response:
Lowering the tailgate of a pickup truck generally increases the drag coefficient and reduces fuel efficiency. Studies and expert opinions consistently indicate that keeping the tailgate up improves aerodynamics by creating a "separated bubble" or "locked vortex flow" that helps reduce drag compared to having the tailgate down.​
AZFox
Arizona
Vehicles
Honda NC700X
If you want to compare two EVs a miles per kWh is the right number to have.
Better yet: KWh per mile.
For some reason it's inverted in the USA. I think the rest of the world does it in Units Per Mile, which makes a lot more sense.
dcgray2
Don
PA
Vehicles
Bronco
AI query:
Response:
Nice to know! Thank you!
metroshot
CA
www.kudo-ume-farms.com
Vehicles
Mach E + Honda PHEV
AI query:
Response:
Yah, they did those tests when the Ford Lightning EV truck came out.
They also found that adding a bed topper decreases range even though it may appear aerodynamic - the weight of the topper outweighed the aerodynamics.
The only thing that does help improve range is lowering the truck to sedan type height which negates the purpose of having a truck.
I still don't understand why people would buy a truck with normal height and lower it - why defeat the purpose of a truck (haul and tow). Maybe people are so vain ?
AZFox
Arizona
Vehicles
Honda NC700X
I think you're referring to what's known as a "camper shell" in my neck of the woods -- as opposed to a bed cover / tonneau.
If so, it begs a question:
How does a tonneau cover affect aerodynamics?
AZFox
Arizona
Vehicles
Honda NC700X
Having owned an S-10 that was lowered, I can answer that.
TL;DR: Lowering a truck slightly doesn't negate the purpose completely, or even much at all. Even bed of an El Camino or Ranchero is still pretty useful.
I owned a 1989 S-10 that that had already been tastefully lowered before I bought it. That truck was one of the most complement-attracting vehicles I've owned, but the main reason for that was probably because I had it made into a convertible.
Like most city-dwelling pickup owners, I rarely hauled heavy loads unless I was hauling some heavy personal belongings during a move. Mostly I just used the bed for things like bicycles and various and sundry items from the Big Box Home Improvement Store.
Consider the Chevy El Camino and a Ford Ranchero. They're cars with beds, not trucks, but still purposeful.
Other than that, as far as the pros and cons of lowering go, there's a thread for that.
cvollers
Chip
Bellevue WA
Vehicles
FJ Cruiser
All unibody “trucks” are cars with beds. Ridgeline, Maverick, Santa Cruz. Even the R1T. I had a buddy in high school with an El Camino…man, that thing was fun. And not unibody.
AZFox
Arizona
Vehicles
Honda NC700X
There's a name for cars with beds (unibody or not): "Coupe Utility Vehicle"
The SUV Kits are CUV-to-SUV conversion kits.
cvollers
Chip
Bellevue WA
Vehicles
FJ Cruiser
This definition of what a truck is is interesting. Does it have to be body on frame to be a truck? Does it need to have a solid rear axle to be a truck? Does it need a pickup bed to be a truck? My FJ has two of the three and I still don't call it a truck. Its a SUV...and definitely not a "car". The Slate has two of the three and to me seems more like a truck. Being able to convert it into a SUV is absolutely brilliant.
AZFox
Arizona
Vehicles
Honda NC700X
Defining what constitutes "truckness" may be above my pay grade.
Not to me it doesn't, but it helps.​
Definitely not. If so, the Slate Truck isn't a truck.​
Flatbeds and box trucks are trucks, so no.​
Is an 80's K-5 Blazer a truck? It could be argued either way.​
AZFox
Arizona
Vehicles
Honda NC700X
On second thought I suppose "unibody" has multiple meanings. I'm not sure what @cvollers has in mind. Behold the 1961 Ford F-100 Unibody Pickup:
Slate Auto Pickup Truck It looks like SLATE has pathetic EV efficiency. (and a rant). 1961_F-100_Unibody_Picku
^^ Looks like a truck to me.
AI Query:
If a motor vehicle is "unibody" what does that mean?​
Response:
A "unibody" vehicle means that the body and frame are constructed as a single piece, providing a more rigid structure that supports the vehicle's weight and holds the suspension and wheels. This design typically results in lighter vehicles that are more fuel-efficient and safer in collisions due to integrated crumple zones.​
AI Query:
What is a "coupe utility vehicle"?​
Response:
A coupé utility vehicle, often called a "ute," is a type of vehicle that combines a passenger compartment at the front with an integrated cargo tray at the rear. This design originated in Australia in the 1930s and is distinct from traditional pickup trucks, as the cargo area is part of the vehicle's overall body structure.​
These vehicles typically feature a closed passenger cabin and an open cargo area, making them versatile for various uses. Over the years, several manufacturers have produced coupe utilities, including the Chevrolet El Camino and Ford Ranchero in the United States. [...]​
GaRailroader
PJ
Atlanta, GA
Vehicles
2018 Tesla Model 3, 2022 Nissan Leaf
AI Query:
Response:
AI Query:
Response:
Note that the bed is integrated to the cab. In a frame truck the bed is attached to the frame and then there is about an inch gap between the bed and the cab which is also attached to the frame.
PJ
Saint Alban
Anton
Queens, NY
Vehicles
Hyundai Kona Electric
Same 😁
Slate Auto Pickup Truck It looks like SLATE has pathetic EV efficiency. (and a rant). IMG_6159
cvollers
Chip
Bellevue WA
Vehicles
FJ Cruiser
The De Dion in the Slate is a solid rear axle. But not a live rear axle in the sense that it drives the wheels.
