Limited upper interior door panel is different
SS_T4R15
New member
Scottsdale, AZ, USA
2015 4Runner Trail P
In one of the review videos I've watched, it was noted that the upper door trim at the window sill, where many of us put our elbow on occation, is hard plastic. I just noticed in a picture that the Limited Tacoma uses a different part in this area that has stiching. I'm wondering if it is padded on the Limited. Can anyone confirm if this is true?
2024 Tacoma Limited upper interior door panel is different Screenshot 2024-02-29 9.03.53 PM
2024 Tacoma Limited upper interior door panel is different Screenshot 2024-02-29 9.06.54 PM
Rick_Shear
Active member
Rick
NW Indiana
2024 Tacoma Limited
Yes, it’s not a thick padding, but it does have a stitched soft vinyl over the hard plastic.
CATOY
Well-known member
NorCal
2024 Tacoma Off Road Premium and 2007 Sequioa LTD
I rest my shoulder on it when I drive and it’s a bit hard and was thinking it would be a great aftermarket idea if someone came out with. Pad you can stick there with double sided tape. The pad could look like the ones that some people use in front of their keypads.
StreeTaco
Well-known member
Dan
2024 Tacoma TRD Pro
You drive weird, all hunched over like that?
CuriousTaco
Active member
Seattle
Jeep Grand Cherokee WK2
I've been thinking the exact same thing since seeing the Limited with it! Great aftermarket opportunity.
CATOY
Well-known member
NorCal
I wouldn’t call it all hunched over as this is one of the few cars I drive where I sit far back and my head is always making contact with the headrest. I lay my elbow on the rest up there and tug at the wheel every 15 seconds or so as I have a long commute and use the adaptive cruise control.
StreeTaco
Well-known member
Dan
2024 Tacoma TRD Pro
Just poking at ya, you stated that you rest your shoulder on the door,, I know you meant Elbow
