They had large vents to exhaust the heat through convection. I don’t imagine this one will be air cooled.The old VW buses didn't get that hot...
If Scout is smart, and I believe they are, they will package this motor in a way that it could be lowered in a single unit. Simply undo some bolts with dampers, and lower it on a hydraulic lift. I'm betting they are going to package this unit not too dissimilar from a generic generator. In the Scouts they will just be connected to some extra wiring and an external fuel tank. Again, I doubt dropping the motor will be for anything but the most in-depth repair.Agreed on a system like that being probably too complex for the benefit, and for oil and filter changes (and anything else on the service schedule) which I'm assuming (hoping) wouldn't be necessary.
But what about repairs requiring access to the cylinder head. What if I need to change an ignition coil pack? There should be an removable access panel in the floor of the bed/trunk allowing that without the need to drop the engine. I'd go further and say there should be an engineering requirement that the only time the engine should have to be dropped is when the engine in a front engine vehicle with an conventional hood would need to be removed for the same procedure.
Because they've decided to put the engine in the rear and under the vehicle shouldn't impose additional requirements on whoever is working on it, whether end consumer, mechanic, etc.
Going back to my earlier comment if dropping this engine is needed more often than for a conventional arrangement it will need to be automated and "idiot proof" if consumers have to do it. But to me the best solution is not having that requirement to begin with.
I would say Scout is thinking along the sames lines as you.If Scout is smart, and I believe they are, they will package this motor in a way that it could be lowered in a single unit. Simply undo some bolts with dampers, and lower it on a hydraulic lift. I'm betting they are going to package this unit not too dissimilar from a generic generator. In the Scouts they will just be connected to some extra wiring and an external fuel tank. Again, I doubt dropping the motor will be for anything but the most in-depth repair.
Think about it this way, why would they make 4 different frames for one 2 vehicles (BEV and REX)? They are going to be able to assemble these on the same lines, and time is money.
TrueThey had large vents to exhaust the heat through convection. I don’t imagine this one will be air cooled.
