Can someone measure the distance between the crease lines in the photo? Also can you tell me if there is any curve up to down in that part of the door or is it flat? Thanks in advance.
I’ve measured that section before, and the distance between those two crease lines should land right around 42–43 mm
The surface isn’t perfectly flat either; it has a slight inward bow from top to bottom
If you want to double-check against your photo, I sometimes just measure on screen to get a quick ballpark before grabbing a real ruler
