1106garage
New member
Jordan
Utah
2024 Tacoma SR5 4x4 6ft bed, Underground
Made a special trip down to Phoenix, AZ to get the truck outfitted at Westcott Designs where we got some test fitting done. Couldn’t be happier with the result. I would recommend Westcott 10/10 times. Their customer experience is top tier and their products are unmatched.
Westcott Designs Preload Collar Lift
Toyo Open Country AT3 285/75R17
Method 703 17x8.5 +35 offset (pokes exactly 1” outside of the fenders)
No rubbing
Another new video:
Updated with @1106garage's 2024 Tacoma build video
2024 Tacoma 4th gen build Toyo Open Country AT3 285:75 and Method 703 +35 offset 1.jpg
2024 Tacoma 4th gen build Toyo Open Country AT3 285:75 and Method 703 +35 offset 4.jpeg
2024 Tacoma 4th gen build Toyo Open Country AT3 285:75 and Method 703 +35 offset 3.jpeg
2024 Tacoma 4th gen build Toyo Open Country AT3 285:75 and Method 703 +35 offset 2.jpeg
univurshul
Well-known member
J.F.
Ram 2001
yeeeea sick looking long boi 🤙🏽
you have to enter in new tread & wheels specs for calibrating speed/mpg etc correct? Or does the computer calculate it automatically another way?
1106garage
New member
Jordan
Utah
It needs to be recalibrated but the tech for the new Tacomas isn’t out yet.
Everything TRD
Active member
US
Tacoma
Damn that looks amazing!!! Do you happen to have a picture straight on from the front and back? I was looking to go 285/75/17 with 17x8.5 +25 but not sure if the tires would look too skinny. I want a little wider setup so maybe 305/70/17 would work better for me. It’s about the same height wise around a 34” but about 1 inch wider. Also, how close are you to rubbing? Did they remove the bracket?
Darrin Carter
Active member
Buckshot
SAULT STE MARIE
2007 Tundra
Looks great and I like that the wheels don’t poke out too much
Do they have that wheel in a bronze?
Fattirz in NC
Well-known member
2002 F-150 SuperCrew
What trim and package did this truck start off as? I’m 100% in on a 6’ bed too! I absolutely love this one, especially those black Method Racing wheels. If I end up with a TH, I’ll likely replace the bronze wheels with these same MR 703 wheels (or 705). I might look to get rid of the 1” poke though and go a tire size down for less rotating mass (better fuel economy), otherwise this is the stance I’ll be looking for.
JED
Well-known member
Southern Tier NY
2015 Tacoma TRD Sport
No rubbing
Perfect! I've got a bronze oxide OR 6' box scheduled to arrive sometime in March and this is IMHO a great presentation for that vehicle! Just to confirm, the preload collars were 2" front & 3/4" rear?
Newtacointown
Well-known member
Kevin
Calgary
Subaru
Would the 285/70/17 tires fit fine with no rubbing without the offset and just the lift?
Steven
Chicagoland
2020 Jeep Wrangler
No rubbing
Truck looks dialed in Jordon, loving it!
-Steven
Echoedlite
Wisconsin
99 chevy silverado
love the truck and could see myself going for something similar; wishing for an OR preem though :(. My biggest reason for getting a tacoma is the 6ft bed for my snowmobile since GM dropped it on their mid size trucks, its so disappointing to see how 'rare' the 6ft bed is especially at higher trims. How is the 6ft for you? anything special you've noticed or more difficult when you were acquiring your truck?
chounder
Well-known member
Jay
Oregon
Honda Pilot
Wish the 6ft Bed was available in the Hybrid OR.
M1KL83
Well-known member
Subaru Forester Wilderness
I wish the 6' was available with 6M transmission. Tradeoffs..I shouldn't gripe, atleast the 6MT is still an option at all.
Fattirz in NC
Well-known member
You sure about that? I thought it would be available with a 6’ bed. With the hybrid not available yet, how would anyone know for sure since the hybrid option isn’t in the configurator. Honestly I’m hoping for the same truck as you if the TH is too pricy or comes standard with features I don’t want on it.
