3231haven
- Thread starter
- #1
Below are the details of the current build level for my 6G MY22 Ranger Wildtrak for those interested.
Vehicle is being setup as a primary touring off road tow vehicle, for our new 3500kg off-road caravan which is currently being built. More changes will be made once I have final weights of full setup of vehicle & caravan setup(max GCM 6400kg) (see below for possible items still to fit)
MODEL YEAR - 22 (August Build)
MAKE - Ford
MODEL & TRIM - Wildtrak
COLOR :-Silver
ENGINE -V6 Diesel
CAB -Dual Cab
DRIVETRAIN (4x4 / 4x2)4x4MODS - Stock
SUSPENSION / CHASSIS -ARB Old Man EMU BP51 remote res shocks with 300kg constant rear leaf springs
30mm lift from factory ride height
WHEELS - CSA 18x8 +35 offset (standard factory +55 offset)
Tires - BF Goodrich K02 LT265/70R18 (same diameter as Raptor 285/70R17) (scope to increase to LT285/70R18)
Spare Tire size limit 828mm
Wheel Nuts replaced with Solid version ( still using shitty sheetmetal covered nuts)
EXTERIOR -
Safari Snorkel
ARB Summit MK2 Bullbar
Rhino Vortex roof racks
Rhino Sunseeker 2.5m Awning
Rhino Shovel holders
Razed Maxtrax holder (up to 4 Maxtrax's )
INTERIOR -
AUX Switch panel in sunglass holder location with full AUX fuse box in engine bay
ARB Front & Rear Floor Mates
ELECTRONICS -
UHF - GME XRS
Twin Rear mounted Anderson plus - 50amp (tow bar mounted)
Future possible options to be added.
Carbon Winch
Steddi Driving lights
Long Range fuel tank (140L)
Safety Dave - Caravan Reversing Camera
ARB Daul Compressor
ARB Jack (HI Lift Hydraulic) - tub mounted
Clear view towing mirrors
Extra 12v Sockets inside vehicle
Vehicle issues so far.
Cracked turbo drain pipe - replaced by Ford
Software updates for the following
-Steering
-Transmission recalibration due to towing temp issue
-Transmission update to correct issue with jumping out of AWD to 4L at slow speeds
-Number of other software upgrades to correct other things ( the new world of modern vehicles)
Also have a special setup for hoisting my disabled daughter into the back seat, which I can post picture for those interested. Hoist also used with our current off-road camper trailer to lift daughter & wheel chair into camper trailer.
MAKE - Ford
COLOR :-Silver
ENGINE -V6 Diesel
CAB -Dual Cab
EXTERIOR -
Safari Snorkel
INTERIOR -
ELECTRONICS -
UHF - GME XRS
Carbon Winch
ARB Daul Compressor
-Steering
