Pre-wiring from factory?
Saint Alban
Anton
Queens, NY
Vehicles
Hyundai Kona Electric
I asked Slate if the add on kit for power windows comes with a wiring harness that we would have to run across the vehicle to the passenger side in order to control the passenger window from the drivers side door OR will the vehicle come pre-wired and the kit would basically be just the switches and motors. Their answer:
“..There is an option to add power windows so you can do that if you'd like but whether it will come pre-wired or if you'll need to do the wiring yourself is still not clear. We assume that it will be pre-wired at the factory, but I've reached out to the appropriate team to get a clear answer. As soon as I hear back from them, I'll update you!….
Thanks for your patience! I followed up with our team and it looks like we're still finalizing details regarding the wiring for power windows so stay tuned!”
cadblu
New York
Vehicles
Tesla
Geez, only 18 months away from target deliveries and still no plan for such a basic option. The reason being, the engineers that are going to make that decision…
… wait for it …
have not been hired yet. :rock:
I think I’m going to just order the basic version and wait until after delivery for customizing / adding options.
B1050
Ben
Lafayette Indiana
Vehicles
Ram, Outback
I wondered the same thing about fog lights. Running the wires will be the hardest part.
E90400K
Francis
Toledo
Vehicles
E90 & Mach E
… wait for it …
This just indicates most of this truck is still vaporware and is being rushed to market.
I also noticed in the reveal video the drivers roll up window was off its tracks, so even the manual window design has yet to be finalized. Also, the relocateable rear window for the SUV conversion was not detailed. It had no latch, no lock, nor gas struts to hold it open.
Lots of work to get through before Job 1.
Swinefuzz
San Diego, CA, USA
Vehicles
'98 Jeep Wrangler
Perhaps this decision is not yet final because the door design is not yet final. If the door will indeed be removeable, which is very, very appealing to me, I hope it will be an easy on/off experience like with my Jeep, which has no wiring or HVAC ducting of any kind jumping the gap and it literally takes just a minute to remove a door! It's the simplest car door design on the planet and has "just worked perfectly" forever.
On the Slate, for door removal to be a quick-n-easy job, it would require none of the air ducting, wiring and hinge stabilization you see on most any common car door. In pics and vids, the Slate's door hinge looks like a common door hinge, telling me door removal will be a tad more complex than I'm used to OR they're planning to redesign it all.
If redesign, hopefully there will be a convenient solution for wiring. On my Jeep's tailgate, which has the 3rd brake light mounted atop it, the wiring is handled with a low-voltage DC contact system that connects when the tailgate is closed, eliminating the need for wires to jump the hinge gap. It is dead simple and has worked perfectly for 27 yrs. Hopefully whatever Slate comes up with will be easy and reliable because I would love to still have easy door removal AND also power windows for the first time in 35 yrs (yes, BOTH). But I realize that most buyers would not be into driving around doorless (why? I mean, WHY?!) so most likely SA will go with a common design.
SichuanHot
Vehicles
BMW E53 X5 3.0i
Unfortunately, I think you might be right. I tried to find Youtube videos that show the door hinge mechanism , but it seems to be glossed over in all the influencer type videos. I did find this still image though and it seems like it's a traditional hinge with the little pushrod arm that dampens the swing mechanism and further recessed hinges behind it. Looks look like there's a little electrical conduit between the door and main chassis that's made from a cloth type material instead of the usual rubber grommet we see on all cars. Of course that might change.
Slate Auto Pickup Truck Pre-wiring from factory? slate_door
Swinefuzz
San Diego, CA, USA
Vehicles
'98 Jeep Wrangler
Yes, I've also taken many a pause looking over various vids and pics and the process looks complicated for door removal. If they're serious about that feature, a redesign is in need, otherwise almost no one will ever do it.
With what looks like a typical bolt-on design you see on almost all car doors, I think you would need to have one person stand and hold a door up while another person unbolts it. No good. What a PITA. That is not DIY-friendly.
The Wrangler's door hinge design is simple and primitive and perfect. You just remove 2 small nuts from the bottoms of the threaded hinge pins, pocket them, disconnect the door swing check strap from the jamb, and lift the door straight up about 3 inches and you're done. It literally takes a minute to do. I love how easy it is to pop doors off and on whenever I want.
Slate Auto Pickup Truck Pre-wiring from factory? 1748185150447-61
Also, another thing I love is the adjustability of the check strap. It's just a simple polyester strap with notches sewn into it so you can adjust the door swing by shortening or lengthening the strap. It takes a second, no tools. I adjust mine often depending on parking situations.
Slate Auto Pickup Truck Pre-wiring from factory? 1748185206073-7
If SA is serious about making the Truck stripped down and bare bones and simple, this would seriously be a cost-cutter for them and a huge convenience+++ for someone like me. It makes the vehicle more DIY-friendly, and more unique to stand out on the market.
Big downside is I don't know if a hinge like this would be compatible with their body panel design.
metroshot
CA
www.kudo-ume-farms.com
Vehicles
Mach E + Honda PHEV
Wonder how much a power window option will cost ?
I'd never really need it as it will be a commuter EV.
Reminds me of the Ford F100 manual truck I learned on with manual windows, manual side mirrors, no A/C and choke throttle knob!
Swinefuzz
San Diego, CA, USA
Vehicles
'98 Jeep Wrangler
I look forward to the price reveal. I doubt it's cheap, but you never know. I don't need them. I'm used to cranks. Out of several owned vehicles, all but one had crank windows. No big deal. But I don't have AC and flying down the highway and leaning over to crank the passenger window is not the best. I've promised myself my next ride will have automatic tx (SoCal traffic jams are brutal when you drive a stick) and power windows. I don't care about the AC.
I find it amusing people find the Slate's window cranks so "retro" and "charming" and "low tech." Young people. Yoots.
cvollers
Chip
Bellevue WA
Vehicles
FJ Cruiser
Door removal might be worth a poll…Admin?
slateya
Minnesota
Vehicles
Audi a4 200k miles, GMC 2500HD 350k miles, Moto Guzzi California
@Slate please don’t pre wire this thing and junk up a simple vehicle at added cost.
Just give room in the panels to run wires later.
SichuanHot
Vehicles
BMW E53 X5 3.0i
The Jeep Wrangler type door makes sense from a simplicity aspect, but then it would be copying something that's a Jeep/Bronco thing. I don't mind the normal door hinge and if it's anything like that of a E46, it will only take maybe 15 more minutes to remove compared to a Wrangler's. I rather like the more streamlined look of the panels hiding the hinges and wouldn't want to see exposed door hinges on the outside tempting thieves.
Swinefuzz
San Diego, CA, USA
Vehicles
'98 Jeep Wrangler
If your car door is firmly closed and locked, then the exposed hinge doesn't compromise anything. Nobody would be able to easily steal ur doors. The perimeter of the door, pressed firmly into the door jamb and locked, couldn't be pulled off just by toying with the exposed hinge. Because the door is recessed into the body of the vehicle, you cannot shift it straight up off the hinge to remove it. You have to unlock the door and swing it open to do that. If you're vehicle's not locked up, however, that changes everything.
The industry standard hinge setup it looks like SA is using probably means removing doors is a two person job, one to hold the door up while the other unbolts everything. That sucks. Or maybe there is a way to shift the door straight up off it's hinge pins like a Jeep, but it just can't be seen in the pictures?
I'm not holding my breath on this door hinge wish. Mostly likely SA is going to stick with their current, industry standard design. They have lots of seasoned engineers on the staff, and I'm sure they've weighed many options already. Also, SA's CEO, Chris Barman, was with Jeep for some time, so I'm sure she's more than familiar with the easy on/off door setup and still chose to go in another direction.
Sigh.
Similarly, I've seen people express dismay at the prospect of people "just walking up the Slate Truck and unbolting body panels" and stealing them. LOL. I doubt the exposed bolts seen around the exterior are the ONLY bolts that hold those panels on. I love the look of them, they look very DIY, very Frankenstein. But if you look at the pictures of the frunk hood open, for example, you see that the fender panels wrap upwards and overlap with the black plastic frunk flange, which has several more bolts that are hidden beneath the hood when closed. Also, the fenders likely bolt down where the fenders seam with the front ends of the doors and likely in the underside of the wheel well. I'll bet all the body panels are like this. So if the hood, doors, rear window and tailgate are all locked, no one's going to be able to (easily) just walk up and steal body panels.
