Rear hatch window issues.
Frcefed579
TRD Pro
51st State (jk)
Current - 25 4runner TRD Pro! Previous - 24 Tacoma TRD Pro.. Bye Felicia!!
I'm running into an issue where I can only lower or raise the rear hatch window from the outside controls on the hatch. The inside switch isn't working at all. I tired the hold it open for 6 seconds, then closed for 2 seconds and the open for another 2 seconds to reset it, but have had no luck.
Any thoughts?
spelingbeachampeun
Trailhunter
Active member
2020 Navigator, 2014 MDX, 1993 Taurus SHO
If the windows are locked on the driver panel the rear window will be locked.
Frcefed579
Frcefed579
TRD Pro
51st State (jk)
I'm an idiot lol. This is my 4th 4runner and I've never ran into this issue.
Window lock was on 😅
Thanks guys!
brumey
SR5
Well-known member
Tennessee USA
F350
Good info to know.... So much in the manual to read when you have to start filtering out the stuff that does not apply to your trim level. I really which that would do a trim level manual, even a pdf.
zgreen
TRD Pro
Well-known member
Zach
Montana
2018 Jeep Grand Cherokee High Altitude
Ahhhhh. Same was happening for me and I was going to stop by the dealer to see what was up. Thanks for the heads up!
