- Thread starter
- #1
I just got my TRD ORP delivered today and the seat memory wasn’t working. The seat would beep whenever I moved it in any direction. Here’s the fix I found on Toyota Nation. Just sharing here in case anyone else has the same issue.
“I have distilled the instructions below … basically, you have to initialize the seat memory feature before you can program it. I guess some dealers do it before handing the car over to the customer, but some dealers evidently do not - go figure!
Here’s the Seat Memory Initialization procedure I found to work:
This procedure is not in the manual, as far as I can see.
To initialize the Driver Seat memory feature, perform the following steps, (starting from outside the vehicle with the driver’s door open):
1. Move the driver’s seat forward to its limit.*
2. Move the driver’s seat to its full height.*
3. Recline the driver’s seat all the way back.*
4. Hold the SET button and press 1.*
5. Move the seat far enough back so you can get back in and sit in it.
6. Adjust the driver’s seat to the desired seat position.
7. Hold the SET button and press 1.
8. Program the key fob, if desired, by following the instructions in the manual.
[*NOTE: Steps 1 thru 4 have to be performed from outside the car with the door open, because the extreme forward and high seat position precludes sitting in it!]”
-Thanks to Pique F at toyotanation.com
