Steering Tilt not going high enough.
TheOldObiWan
TRD Off-Road Premium
Josiah
2024 Taco
I’ve had my 24 TRD OffRoad since January and I just feel like I’m missing something.
I just feel like the steering wheel needs to tilt up about 1 inch more.
I hit the top of my thigh as I get in and out on the bottom of the steering wheel. I will admit that I am short (5’7”) but I don’t have my seat in the highest position and I’m not sitting on a stack of books.
I have attached photos. I pulled the telescoping out all the way to see it better. The one is the steering wheel tilted to its lowest position and the other at its highest position. I feel that my driving position is pretty standard. I’m not sitting straight backed or reclined. And my reach to the pedals is comfortable.
Is anyone else seeing this as an issue with their driving position? If there is further adjustment that can be made I’d love to know.
2024 Tacoma Steering Tilt not going high enough. IMG_4881
2024 Tacoma Steering Tilt not going high enough. IMG_4882
mattski2112
Well-known member
Georgetown, TX
2024 Tacoma TRD Off-Road Premium, iForceMax
Totally and completely agree. I don’t have a solution except to lower my seat height a bit and learn to live with it. I do wish the wheel tilted a good inch higher.
Goriders
TRD Sport
Well-known member
Calgary
2024 Tacoma Sport Plus
I have my seat as far back and as high as it will go and I don’t have any issues. At least not that I have noticed. Maybe I will notice it now that you brought it up.
jettaway
TRD Pro
Active member
Maryland
TRD Pro
Same. Probably design over site for us tall people with long legs. I’m just learning to get used to it.
Nacho TacoMan
Limited
Active member
Paul
2025 Tacoma Limited. 2018 BMW X5 335d
My’25 is the same. I also noticed that the seat can go down farther but then I feel like that little old lady driving just staring at the cluster. I have my seat up quite a bit so that the hud is more in focus and visible. I too am trying to just get used to it.
ollie03031
SR5
ollie
New Hampshire
tacoma
I am only 5’ 10” and I can’t get my seat low enough to feel comfortable. I am almost hitting my head on the roof when I get in and don’t like the seat way back because then my arms are almost straight to reach the steering wheel but moving it closer has my knees hit the underside of the steering wheel. I have no up and down motion of the seat only forward and back and the back of the seat will lean back. I have a button that shows up and down but it just inflates the back support. I would love another inch in upward travel of the steering wheel Or the ability to lower the seat and inch or more.
Kyle_Ennis
SR5
New member
Kyle
Oxnard, Ca.
2025 Toyota Tacoma SR5
You should have another lever next to the recline lever that will let you raise and lower the seat. I also have a SR5 and was able to adjust the seat to a nice position and no issues with hitting the steering wheel. Hope that helps.
ollie03031
SR5
ollie
New Hampshire
tacoma
Will check next time I am in the truck. From memory I have three levers. 1) forward and backwards. 2). Reclines or tips the back forward And backward. ( This is an extended cab not 4 door) 3) the up down button that just seems to inflate the back forward more support. But I will both check the manual and for more buttons.
Kdbradley85
TRD Off-Road
Well-known member
Kevin
Maryland
2024 Toyota Tacoma TRD OR MT
Y’all just need to face up to the fact that you have weird shaped bodies! I kid… it would be nice if there were a bit more adjustability to the steering wheel, but personally, this truck fits me like a glove lol. I also have my seat adjusted to max height and the wheel is very close to my thighs, but that’s the driving position I prefer. It’s definitely not the easiest truck to get in and out of, and my right knee makes contact with the hard plastic on the center dash next to the wheel if I slouch when I’m driving, but It’s still a super comfortable ride if I’m comparing it to my 3rd gen, especially.
Goriders
TRD Sport
Well-known member
Calgary
my forward and back button also does up and down.
Goriders
TRD Sport
Well-known member
Calgary
it’s more like a fighter jet and less like a minivan
nurp42
TRD PreRunner
Well-known member
SoCal
'24 PreRunner
You should have a bar under the seat to move forwards/backwards. Located along the lower side of the seat you'll have the lumbar control (electric) first, just behind that two levers---- the first lever moves seat higher/lower and the back lever adjusts the recline angle of the back. My guess is that you will be able to lower the seat position if you push down on the lever nearest the front (if just reaching while sitting it can be easy to grab the wrong one). I've got the xtracab as well and it works fine.
quick edit: just realized that you may have the power seats----if that's the case please disregard. I have the manual seats and sometimes it's easy to reach for the wrong lever.
ollie03031
SR5
ollie
New Hampshire
tacoma
nurp42, I have the setup just as you describe. The electric lumbar button then the next lever seems to do nothing for me. it will lift up or push down but nothing seems to change than the last lever does the recline. I will investigate the middle lever some more next time I am in the truck.
ollie03031
SR5
ollie
New Hampshire
tacoma
Ok, got it figured out. That center lever for up and down needs to be pumped. For every time you lift the lever up it raises your knees and lowers your but. Pushing it down lowers the knees and raises the but. Every push lowers or raises about 1/4 inch. You have to push it multiple times to feel any real results. Thanks guys.
magicbenjils
New member
Ben
Utah
2024 TRD ORP
The lack of steering wheel tilt adjustment was the first thing I noticed coming from an ‘02 Tundra, and was almost a dealbreaker for me. I wonder if it’s a safety thing (steering wheel angle in a crash, etc.)
