Subwoofer install by a guy who isn’t handy - it worked!
Sauce
Northeast
2025 Ranger XLT FX4
I just installed a Memphis Nano subwoofer behind the rear seat in my 2024 xlt. I have no experience with a job like this but did a bunch of research beforehand and it turned out great and really improved the sound. My goal was to fill out the bass on the stock system - not looking to rattle my fillings out - and I think the goal was accomplished. Here are some tips and thoughts having just done this.
Memphis Nano - this sub was recommended to me over the Kicker. Very similar specs but I was told the bass was a little more accurate vs the kicker. Haven’t heard them both side by side but it sounds great to me. It has a bass boost feature and I was told a LOC wasn’t really necessary unless I was planning to upgrade the whole system. Note that the system doesn’t include wiring and I got a full wiring setup from Crutchfield. The sub fits very snug behind the rear seat in a vertical orientation - it is hard to lock the seat in place and anything bigger would not fit. I think it might fit a little better horizontally but it would be hard to access the controls if I wanted to change anything.
I tapped high level speaker wires from the rear door speakers for my install. These were tapped on both sides at the front door trim which provides access to the wiring harness. Some people say the rear door speakers run through the back of the vehicle but I couldn’t find the speaker wires under the rear door trim and I think they are only run from the front.
Left rear speaker wires are gray violet and brown green. Right speaker wires are green violet and gray. I don’t remember which are positive and negative. Everything matched up with the ford wiring diagram. The speaker wires on each side are coiled around eachother so they are pretty easy to identify. I used positaps to make my connections and they feel solid and there is enough room for them under the trim.
For power I ran through the firewall on the driver side. I punctured it with a poker (note it is two layers) then taped the wire to a screwdriver and pushed it through. This wasn’t too hard with two people but would have been a big challenge alone. For my ground wire I used the rear child restraint bolt and sanded some of the paint off around the hole.
I used the door trim to run all wires to the subwoofer. A wire worm tool was very helpful for this and allowed me to run the wires without completely removing all of the trim. Note that the trickiest part was getting from the rear door trim around the back seat to the subwoofer. I had to diverge from the oem runs here and it is pretty crowded to run them at this point on each side. It might be easier if i had removed the seat. I used plastic cord wrap here since there are some angles and pieces of trim rubbing. Be careful not to bend the trim clips when you put things back together.
I haven’t actually mounted the sub yet but it doesn’t rattle and isn’t going to go anywhere given how tight everything is back there. There is basically no room for a mount anyways.
I was concerned that I would get the artificial engine noise through the sub, but I’ve done some hard pulls and revs since I installed it and there is zero perceivable engine noise coming through the sub. Not sure if that feature is disabled in my build or if the sub is somehow omitting that signal but it’s not an issue at all for me. I also don’t get any of the system alerts or anything like that through the sub. The auto on feature works perfectly with the high level input. Basically it behaves exactly like I want and thankfully there were no surprises.
Overall, I’m very happy with the Memphis sub given the size constraints and the install took me about four hours with a helper.
One thing to mention is that the sub has an Aux volume control that I ran to the drivers seat area. I’ve played around with it and I’m not finding it does anything. The gain control on the actual sub definitely works but I don’t see any difference with the volume control and I probably wouldn’t bother installing it if I did it again.
Oh yea - the Memphis sub has a cool light and you can change the color.
localhost
2024 ranger xlt
Do you have any pics of the install? What tools did you have to use? Did Crutchfield have installation instructions?
Sauce
Sauce
Northeast
2025 Ranger XLT FX4
Nothing from crutchfield. Other than basic tools (my hands, screwdrivers and a rock) I used wire strippers (a lot), wire worm (multi section from Amazon), wire loom tape (a lot), positaps (both T and butt end), and that’s about it. Having a brother in law who wanted to help was the best tool I could have had. I had 3 or 4 beers if those count as tools.
I did use a cigarette lighter 9v battery adapter to make sure I didn’t lose my vehicle settings. Not sure it was necessary. The vehicle kept my phone memory but my audio presets were lost.
Sorry no pics.
Sauce
Sauce
Northeast
2025 Ranger XLT FX4
Just confirmed Left rear speaker wires are gray violet (positive) and brown green (negative). Right speaker wires are green violet (positive) and gray (negative).
localhost
2024 ranger xlt
Thanks for the update. You have inspired me to install one my Ranger.
crank_powered
dylan
norcal
2024 ford ranger XLT FX4
Did you have to connect a remote line? Can you link the wire diagram you were using?
Sauce
Sauce
Northeast
2025 Ranger XLT FX4
I think you mean a turn on signal? If so, no. The sub has an auto on that will turn on when it senses a hi level signal through the speaker wires. There is an option to have a turn on wire that I could have tapped to a fuse but the auto on function works fine for me.
I just used the wiring diagram provided w the sub but it was very simple. run + power (through an inline aux fuse that came with the wiring package I got from Crutchfield) from the battery to the sub. Run a ground from the sub (grounded to chassis). Tap right and left rear speaker wires (+ and -) and use those as hi level input to the sub. I also ran the remote volume wire but not sure it was necessary.
The wiring configuration is very simple to figure out. The hardest part was actually running/fishing and concealing the wires. The speaker wire identification I posted in this thread took a bit of research but now that it’s here it should make it much easier.
If you have an oem sub in your truck I think you can forgo the hi level input but I’m not 100% sure of what the wiring looks like. My truck didn’t have a sub.
