Suspension Upgrades?
[email protected]
Phoenix, AZ
www.stage3motorsports.com
2011 F150 5.0L
Web Team Overlord
HenryMac
Central Colorado
2019 Ranger SuperCab XL - STX - FX4 - Magnetic
Vehicle Showcase
For the rear shocks, you technically don’t have to lift the truck at all. You’ll just remove the stock shocks, bolt the top mount of the new shock, and the. essentially bench press the lower mount into place.
It is easier if you get the frame up on jacks and let the axle hang, however.
Fronts, you absolutely need to get the truck up in the air.
For the fronts don't you also need a spring compressor? If the fronts are changed does that require a front end alignment too?
[email protected]
Phoenix, AZ
2011 F150 5.0L
Web Team Overlord
Any ETA on the Bilsteins?
Unfortunately, no.
Frankly, I’m pretty surprised that they’re not already out.
For an Eibach front install, you’ll absolutely need a spring compressor, and an alignment is highly recommended if you’re changing ride height.
If you’re doing a complete coilover like a Fox 2.0 or ICON/King 2.5, a spring compressor will not be required.
CompDude
Ozarks, MO
13 Escape SEL 2010 RAV4 Sport
PAID GEEK
What are the factors for reusing the factory spring?
I assume 0 lift will be OK but can you reuse the factory spring with a 1 or 2 inch strut lift?
I am assuming you can due to the collar just moving up the strut for the lift.[/QUOTE]
FULLSCALE
Adam
Ontario, Canada
2019 Ford Ranger Lariat FX4 Supercrew, 2011 Mazda 3 Sport GT-E, 1968 Ford Mustang
You can use factory springs for 0”, 0.75”, 1.5”, 2.25” or 3” lift.
[email protected]
Phoenix, AZ
2011 F150 5.0L
Web Team Overlord
The Eibach struts are designed for the factory springs, and all their ride height gains are due to the preload caused by the different perch settings.
Reusing the stock spring is fine, you just have to keep in mind that getting higher ride height means more preload which stiffens up your ride a bit.
Psykostevo
Queen Creek, AZ
2019 Ford Ranger
Vehicle Showcase
Is there a rear shock that lowers the rear to be level with the front? Seems like all the leveling kits just want to raise the front. But I think I’m not alone with wanting to slightly lower the rear on these 2WD trucks.
joeb427
Joe
Fort Mill/Indian Land area South Carolina
'19 Lariat Sport and 19 Lincoln MKC Reserve
Vehicle Showcase
If I could have lowered the rear at the time, I wouldn't have gone with spacers.
kieefer
kieefer
Tennessee
2019 Ranger Lariat SuperCab
Shock absorbers do not effect height.
The rear spring determines the height and payload. There is a thread you can follow concerning lowering the new Ranger if you haven’t found it yet.
A cheap option IMO would be to remove the rear overload spring and add air bladders/shocks when load carrying. But I suspect the ride may suffer.
HenryMac
Central Colorado
Vehicle Showcase
Removing the overload spring will only drop the rear about 1/2".
kieefer
kieefer
Tennessee
Have you done it?
Without the overload the main spring will flex more, I’m thinking an inch or more.
At least that’s been my experience with past trucks I’ve fooled with.
HenryMac
Central Colorado
Vehicle Showcase
None of which were monoleaf springs... right? Totally different design, they are different than multi-leaf springs.
kieefer
kieefer
Tennessee
Ok
Still, lowering the rear on the new Ranger is going to be a trick.....and expensive.
