Taco Bill
- First Name
- Bill
- Joined
- Mar 12, 2024
- Threads
- 1
- Messages
- 8
- Reaction score
- 34
- Location
- Austin, TX
- Vehicle(s)
- 2024 Tacoma TRD Off-road
- Thread starter
- #1
Hi folks, my name is Bill and I’m a proud owner of a 2024 Tacoma TRD Off-road Premium (Black). My build date was 12/2023. I took delivery of my truck on 2/16/24.
I’ll be posting updates of mods on this thread.
Here are a few mods so far -
Tires: 285/70/R17 BFG KO3 Load range: C
(Thanks to the guys @Discount Tire)
Wheels: Method 703 17x8.5 35mm offset
Tint: 30% All around (FormulaOne Stratos) | 90% front windshield (Llumar Air clear)
Mods (on the way)
- Taco Bill
- The new KO3s are fantastic. The truck feels much more planted over the stock tires.
- Steering - IMO the steering was too light with the stock tires. Personal preference but the steering feels much more assertive and positive with the KO3s + increased tire size/weight.
- Road noise - The increase in road noise is negligible.
- Ride quality - I was expecting the ride quality to suffer with bigger/heavier tires, but I actually observed the opposite. The ride quality is improved perhaps because of the higher silica content in the KO3s.
- No rubbing!
- I’ll follow up re - long term performance / wet weather (should be improved due to new sipe pattern)
- KO3s are ~6 lbs heavier than KO2s in the same Load Range C (56 lbs vs 50.33 lbs)
- KO3s should have improved wet road performance due to new sipe pattern/depth (In theory)
- KO3s should have improved cold weather performance (likely due to more silica content so they remain pliable in cold temps) (In theory)
- With 35mm offset, I measured 1/2” of poke (See photos). Perfect IMO
Mods (on the way)
- weBoost Drive Reach Overland
- AluCab ModCap or Contour Canopy(Pending confirmation via CB Adventure Supply)
- Dometic CFX3 25 + Anker SOLIX C1000 Passthrough (Might delete the 40% seat for a permanent fridge and power solution)
- Suspension lift - TBD (Most likely the OEM TRD lift when it becomes available)
- Roof rack - Prinsu Pro (Still shopping around)
- Dual battery / or other power system (TBD)
- Taco Bill
