Wheels Specs - Bolt Pattern / Offset? Tire Size Change Via App?
5ohbrad
Brad
Mansfield, Texas
Vehicles
Nissan Frontier
Curious about wheel spec. What bolt pattern and offset is it? Also, can the end user adjust speedo/odometer calibration for change in tire size? OTA update from your phone to adjust in app would be an amazing feature!
AZFox
Arizona
Vehicles
Honda NC700X
In particular I'd like to know if a 16" wheel can be fitted.
A 16" wheel is lighter than a 17 and provides 1/2" more sidewall height.
I looked up my likely tire choice. It weighs two pounds less in 235/85R16 compared to 235/80R17 (44 pounds vs. 46 pounds). Lowering un-sprung weight by installing a lighter tire and wheel with a taller sidewall provides advantages, including an efficiency advantage.
Slate Auto Pickup Truck Wheels Specs - Bolt Pattern / Offset? Tire Size Change Via App? 235-85-17_stats
Slate Auto Pickup Truck Wheels Specs - Bolt Pattern / Offset? Tire Size Change Via App? 235-85-16_stats
UFO CTR
Bernie
Merced, CA
Vehicles
Tesla Model 3
lighter wheels always helps
