2019+ Ford Ranger Dual 30" PRO Light Bars - Behind-the-Grille Setup
MandRonline
Gold Sponsor
Jesse
Burbank, CA
Ford ranger raptor
operation overseer
2019+ Ford Ranger - Dual 30" Grille Light Bar Upgrade
If you've been wanting to add some serious lighting to your Ranger without changing the look of the front end too much, this setup is worth checking out.
It runs two 30" slim light bars behind the grille, giving you both distance and a wider spread of light. The mounting brackets use factory points, so there's no need to cut or drill anything.
Both bars are available in white or yellow, with amber DRL backlighting.
Slim Light Bar Showcase:
Take a look here:
https://mandronline.com/products/2019-ford-ranger-dual-30s-light-bars
Ford Ranger 2019+ Ford Ranger Dual 30" PRO Light Bars - Behind-the-Grille Setup Ford-Ranger-Dual-30s-Light-Bars-2019-2023-front-view-off-road-fitment-quick-bolt-on-no-drill
MandRonline
MandRonline
Gold Sponsor
Jesse
Burbank, CA
Ford ranger raptor
operation overseer
For the Ranger owners who haven't seen this one yet, here's a closer look at the dual 30" setup behind the grille. It's a way to add more lighting up front while keeping the factory front-end look intact.
The bars are available in white or yellow, both with amber DRL backlighting.
More info here:
Ford Ranger 2019+ Ford Ranger Dual 30" PRO Light Bars - Behind-the-Grille Setup ford-ranger-dual-30s-light-bars-2019-2023-off-road-installation-bolt-on-no-drilling-black-met
