MandRonline
Gold Sponsor
- First Name
- Jesse
- Joined
- May 30, 2025
- Threads
- 11
- Messages
- 42
- Reaction score
- 27
- Location
- Burbank, CA
- Vehicle(s)
- Ford ranger raptor
- Occupation
- operation overseer
- Thread starter
- #1
*** Don’t Forget: Forum Members Receive a 10% DISCOUNT!!! Use Coupon Code RANGER6G ***
Hey guys,
Check out our shiny new website and check out the 2024+ Ford Ranger Reverse Light Kit by M&R Automotive to give your truck up a glow up on the next adventures.
This kit is super easy to install:
1) No drilling. Complete bolt-on.
2) Lifetime warranty
3) Can tap directly into your AUX switches if equipped. If not we have a perfect solution (M&R Wireless Harness)
Fits: 2024–2026 Ford Ranger
Trims: XL, STX, XLT, Lariat
Our light kits are for off-road use only.
For More information on the 2024+ Ford Ranger Reverse Light Kit by M&R Automotive, click HERE
Hey guys,
- Each kit comes as a PAIR of pods
- Flood Pattern: longer and wider beam focuses for illumination further down the trail or road as well as peripheral angles
- main White LED light -- you choose your backlight (amber or red)
- 1) Amber back light that can be wired as turn signals
- 2) Red backlight that can be wired as turn signals or brake light
- Each LED light pod is attached to a metal bracket on each side
- No cutting or drilling required. The kit is a complete bolt on
- Uses a TIR (Total Internal Reflection) lens, which is different from the conventional optics parts, which lose some light internally and produce glare. The TIR lens collects all of the light from the LED and directly leads them to where you need, drastically reducing glare and improving total efficiency.
- Higher light efficiency: brighter, longer irradiation distance
- Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to protect against UV, salt water, corrosion, fading and scratch resistant.
- Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
