2024+ Ranger Owners: Flood-Pattern Reverse Pods for More Light When Backing Up
MandRonline
Gold Sponsor
Jesse
Burbank, CA
Ford ranger raptor
operation overseer
2024+ Ford Ranger - Reverse Light Kit
Ford Ranger 2024+ Ranger Owners: Flood-Pattern Reverse Pods for More Light When Backing Up 2024-Ford-Ranger-Reverse-Light-Kit
Fitment
  • Fits 2024–2026 Ford Ranger
  • Trims: XL, STX, XLT, Lariat
Install
  • Each LED light pod is attached to a metal bracket on each side
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware
Ford Ranger 2024+ Ranger Owners: Flood-Pattern Reverse Pods for More Light When Backing Up mr-automotive-2024-ford-ranger-reverse-light-kit-1
Light output
Each PRO light pod uses a Flood Pattern, the widest spread of the three beam types, built for close-range visibility all around the vehicle rather than long-distance throw.
Every kit is dual function, off-road white main light that runs alongside your choice of backlight color.
White main light
Powerful white LED that lights up everything behind you when backing up at night.
Amber Backlight
Red Backlight
Build quality
  • Higher light efficiency: brighter, longer irradiation distance
  • Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to protect against UV, salt water, corrosion, fading, and scratches
  • Equipped with a thermal management system that automatically adjusts brightness output according to external temperature
  • Rated for a 50,000 hour lifespan
Ford Ranger 2024+ Ranger Owners: Flood-Pattern Reverse Pods for More Light When Backing Up mr-automotive-2024-ford-ranger-reverse-light-kit-2
Questions about fitment on your truck? Ask here and we'll help.
MandRonline
MandRonline
Gold Sponsor
Jesse
Burbank, CA
Ford ranger raptor
operation overseer
Another look at the PRO reverse pods on a 2024+ Ranger.
Ford Ranger 2024+ Ranger Owners: Flood-Pattern Reverse Pods for More Light When Backing Up ranger-revers
  • Fits 2024-2026 Ranger in XL, STX, XLT and Lariat
  • PRO pods with a flood pattern, which is the widest spread, built for close-range visibility around the truck
  • Dual function, with a white main light plus your choice of an amber or red backlight
  • Each pod mounts on a metal bracket on each side
  • Complete bolt-on kit that uses the factory openings and hardware, with no cutting or drilling
2024+ Ford Ranger Reverse Light Kit
MandRonline
MandRonline
Gold Sponsor
Jesse
Burbank, CA
Ford ranger raptor
operation overseer
For 2024+ Ranger owners, here's another look at the flood-pattern reverse pods.
These add to your factory reverse light instead of replacing it. The flood pattern spreads the light wide behind the truck, so you can actually see what you're backing toward at night.
