ajs112
- Thread starter
- #1
I’ve gotten a lot of help from you all just reading through questions so figured I’d grab a list of everything I’ve done to date in case folks have questions! Pics for each mod are attached below along with some fuse box diagrams I was able to dig up - I think Jon52 originally posted.
1.) Wired Raptor Ambers to accessory power so they stay on while driving. The ambers from F150 LEDS. Beware as these were a pain to install and required some modification to the grille.
I’m curious what you all think about how they look wired to accessory power. I originally had it wired to the driver side trim light but wanted them on all the time so this is the route I went. If you all have suggestions on a “DRL always on” on option without FORSCAN use, I’m all ears!
2.)F150 LEDs ambiance lighting around the bottom.
3.) Installed front and rear dash cams.
4.) Trailing Arm sensor skid plate - driver and passenger.
5.)Ford OEM Bed Extender. (You can likely locate something better than OEM)
6.)Red inlay on Raptor badging on tailgate.
7.)Domed Carbon Fiber Ranger Inlay
7.) Reflective topo front FORD grille overlay
7.) Short antennae
Installs on the way:
1.) Carbon fiber caps for mirrors, hood and side vents from Indie Carbon
2.) Hood Strut
3.) Side vent lighting wired to driver side trim light
4.) Skid hitch with Red D Ring
5.)additional skid plating
6.) Red inlay for “Raptor” on running lords and running board hole fill.
7.) Will be polishing and applying ceramic coating next weekend.
8.) Ford Performance tune - scheduling with the dealership.
9.) Diamondback or Peragon cover when they are back in stock
7.) Short antennae
2.) Hood Strut
