Anyone installed DRL fog light “Fang Lights”?
robfultz
TRD Off-Road
Well-known member
Rob
Maryland
2024 Tacoma Off Road
Ok. I had the issue with lights coming on randomly. Tried multiple fuses in the fuse box under the hood…no luck.
read somewhere the fuse box under the passenger side dash was the one to use.
Used USB 2.
No more random lights.
TFOUTS
Trailhunter
Well-known member
Timothy
Northwest Florida
2024 Tacoma Trailhunter, 2003 Tacoma TRD , 2003 Toyota Sequoia
On this column are 4 20a yellow and 4 10a red fuses. The last one next to the empty slot
2024 Tacoma Anyone installed DRL fog light “Fang Lights”? IMG_5008
dvrgz
SR5
Well-known member
Los Angeles
2024 Toyota Tacoma 4x4 Long Bed
Diggin these fang lights. Anybody have them? Tacomalifestyle has no ETA on a restock. Does anybody else make something similar?
2024 Tacoma Anyone installed DRL fog light “Fang Lights”? IMG_9590
holden
TRD Pro
Active member
Holden
Scottsdale
'24 Toyota Tacoma TRD Pro
I would suggest not buying the Tacoma Lifestyle kit. It’s overpriced for what it is. They all function the same but just behind a different name.
These are my cheap amazon versions that I installed myself. I tinted them myself also. The white LED bars were just too much. Needed a more oem look.
They look and function just like the Toyota Lifestyle version. In all, probably about $80-90 spent including the tint.
How did you tint these? I received mine yesterday and I agree the white LEDs are too much.
Novax
TRD Off-Road
Michael
Novnov111!!!
Tacoma 2024
Used USB 2.
Did this work? Because I just installed mine and it turned on randomly and j don't want to kill my battery
robfultz
TRD Off-Road
Well-known member
Rob
Maryland
Yes, running into the passenger compartment to the USB2 fuse worked.
TFOUTS
Trailhunter
Well-known member
Timothy
Northwest Florida
Ever once in a while, the lights will turn on randomly, but they’re only on for a few seconds and then they’re off. I have had the lights for about 2 1/2 months, I’m not worried about it. The photo was just to show where they are plugged in the driver side under the hood fuse box
robfultz
TRD Off-Road
Well-known member
Rob
Maryland
2024 Tacoma Anyone installed DRL fog light “Fang Lights”? IMG_0277
Just run your Red power wire to this firewall behind the battery - There is a nipple there. Nip off the end and run the red wire through it (will need to add a length of wire to make it longer). It will come out right above the interior Fuse box on the passenger side. Attach a fuse tap and use the USB2 fuse.
You will need to remove the panel under the passenger side dash to access the fuse box (4 clips to push and pull down.
The fuse box lid will not go back on with the fuse tap. I just used electrical tape to lightly attach it back or you could just leave it off and put it the cover in the glovebox.
Lance
Bonney Lake, WA
2025 Toyota Tacoma TRD Offroad Club Cab Long Bed
I think I am on the same path as you but with ditch lights. Let me know how you've done. I'll let you know if I get anywhere as well.
