Use Micro2 fuse tap. Note that you might want to consider an OBD2 power supply for a more basic setup as the OBD2 power supplies come in various formats, depending on your camera brand or power connection type, and it is very easy to install this type of power setup as it uses your existing OBD2 port and there is no need for a fuse tap and ground wire.
If you need a more complex setup, use taps.
If you are tapping, use:
Fuse slot 28 for constant power
Fuse slot 35 for accessory power (power on when driving or when key/button is in accessory position).
Make sure your tap wire exits fuse tap on the left side as power flows from right to left. If you put it in backwards your dash cam will not be fused.
Also, you can ground your power setup beside fuse box on upper right side; there is an existing ground bolt there.
