Sold: Washington Ford Ranger Raptor 17" Wheel set (Bead lock) OEM like new
bdallas9
Washington
sales
Wheelset off of my 2024 Ranger Raptor. Low miles (1200) on them with a couple small marks. These will fit any Ranger and Bronco. I have plasti dipped the lock rings to make the wheels all one color. This can easily be removed. These do not come with TPMS sensors but I had included the OEM lug nuts.
I will ship to any address in the US at the buyers expense.
Key Specifications:
Diameter: 17 inches
Width: 8.5 inches.
Bolt Pattern (PCD): 6x139.7mm
Center Bore: 87.1mm
Offset: Around +50mm to +55mm
Backspacing: About 6 inches (152mm) or 177.5mm.
Material: Aluminum alloy, often with a matte gray finish.
Features: Beadlock-capable for low-pressure off-roading, compatible with factory TPMS sensors.
Ford Ranger Ford Ranger Raptor 17" Wheel set (Bead lock) OEM like new tempImageutobu
Ford Ranger Ford Ranger Raptor 17" Wheel set (Bead lock) OEM like new tempImagePkaeN4
Ford Ranger Ford Ranger Raptor 17" Wheel set (Bead lock) OEM like new tempImagei2Gf5j
Ford Ranger Ford Ranger Raptor 17" Wheel set (Bead lock) OEM like new tempImagecKU0au
Ford Ranger Ford Ranger Raptor 17" Wheel set (Bead lock) OEM like new tempImageYoI6Yy
Ford Ranger Ford Ranger Raptor 17" Wheel set (Bead lock) OEM like new tempImage5L7OCS
Ford Ranger Ford Ranger Raptor 17" Wheel set (Bead lock) OEM like new tempImageobdd8C
bdallas9
bdallas9
Washington
sales
Sorry. $1500 plus shipping or local pick up
John E Davies
Spokane WA USA
Retired aircraft tech
Please post your actual location. Thanks.
DHOGY
2024Ranger_Raptor
2024 Ranger Raptor /Shelter Green, 2023 Ranger FX4 Level II
Mechanical designer
Arsenll11 do you still have them?
