Hard transmission shift on initial startup under 1k Miles
Hobb3s
Limited
Well-known member
2012 Jeep Grand Cherokee
Hey all,
has anyone experienced a hard transmission shift for 1st and 2nd gear when initially starting the 4runner, the transmission shifting smooths out almost instantly after that.
curious if anyone has experience this and if its anything to worry about/is there a fix
im running a limited non hybrid
EarthPIG_0311
Limited
Well-known member
The 90660
'25 4Runner Limited i-Force Max, '20 Civic Si
I personally have not felt that.
Are you experiencing this before the engine reaches operating temperature?
The only hard transmission change I've felt (2x) is going from D to R. Both times I thought I came to a complete stop but apparently I didn't b/c when I went into R, I felt the car move/clunk. Since those experiences, I've made sure I'm completely stopped before changing into R and haven't felt it since.
ah4rsr5
SR5
Well-known member
Abraham
VA
2025 4R SR5
My sr5 does the same thing. Shifts from 3 and on is smooth and quick. But that first shift is rough. Even when warmed up.
Hobb3s
Limited
Well-known member
its only when the engine has not warmed up… its litterally the first 2 shifts when the 4runner has been sitting for a while
Hobb3s
Limited
Well-known member
mine is only the first 2 shifts when its been sitting for a while, then 1 and 2 are smooth.
im hoping its just part of breaking it in.. how many miles do you have on your sr5?
ah4rsr5
SR5
Well-known member
Abraham
VA
2025 4R SR5
About 300-400 miles. Very early in the break in. Curious about others that are broken in
FoozGrind
TRD Sport Premium
Well-known member
4runner
I have some weird shifting from 2-1 mostly when braking when I am braking and it’s getting into 1st I feel like the engine brakes also and it’s making it feel like I am pushing harder on the brakes than I actually am. I don’t have that PDA on. Could just be me also and not being used to new type of transmission from 5th gen
Hobb3s
Limited
Well-known member
how many miles do you have on your 4runner?
cic44
TRD Sport Premium
New member
NJ
2025 4Runner
My TRD Sport Premium non-hybrid is doing the same thing: hard shift from first to second. I have 800 miles on it.
Hobb3s
Limited
Well-known member
is it the initial first couple shifts and then smooths out after? like 1 and 2 are fine after
cic44
TRD Sport Premium
New member
NJ
2025 4Runner
Usually only initially, though it has happened a bit later when accelerating quickly onto roadways.
Racinwith8
TRD Sport Premium
Ron
KY
2022 4Runner Limited Nightshade, 2023 Acura TLX A spec
Same thing on my Sport Premium with about 400 miles. Mine occurs like second to third. It’s not like a hard shift, but a subtle “thud”. Everything else is silky smooth. Only occurs on the upshift, nothing when it’s downshifting to slow.
ah4rsr5
SR5
Well-known member
Abraham
VA
2025 4R SR5
if I'm in traffic and i lightly accelerate then quickly get off the gas, the car definitely has some clunk on the transmission too... i know its not a shifting thing but something about quickly getting off the gas pedal after a small acceleration (under 10-15mph... maybe even less) feels like its jerking
Vlad23i
TRD Off-Road Premium
Active member
Vlad
California
Trd off road 4runner 2025
At 2300 miles and same thing trd off road
