New 2025 Ranger Raptor 2.0 (my second RR) Build.
Update:
it did get delivered today.
The tracker updated to delivered status this evening.
The info the Ford Chat rep found today was spot on.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_5769
A clean slate
Yep, so far I have my F150LED Raptor grill lights ordered.
I plan to order the topper and Bed Rug for it next week once I have made it home with it.
I already have another set of Bronco SAS wheels out in the barn; with the 34" tires I use to have on my 2024 model RR. I plan to put those on the 25 model soon as I get it home.
I order some more ford center caps for them since the only set of certers not in use have the Bronco logos.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. 1758123519126-bv
From the Ford dealer I ordered the Ford molded splash guards and rubber bed mat.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. 1758123572156-n6
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. 1758123598871-tf
I have plans to get the windows tinted. Ceramic 20%
I am on the fence as to do a spray in liner since I am getting a bed Rug liner with my topper.
I may also get the undercoating done on this one.
With the topper it will likely become my go too winter daily driver.
Rougarou
NorCal
2025 Shelter Green Ranger Raptor
I like the plain Ford caps, but since it’s a RR, did you consider the Ford Performance caps?
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_7105
It was a long day, but 2.0 is now home.
11 hours round trip going after it today.
Goodby Defender 90 v8.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4250
Hello Ranger Raptor 2.0 project begins.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4251
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4252
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4254
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4253
Had to take a couple pics when I got it home with its older brother.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4265
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4260
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4264
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4261
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4262
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4267
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4266
Next I had to get those wheels and tires swapped out.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4270
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4272
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4274
All done except the TPMS relearn is giving me some issues.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4277
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4282
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4280
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4279
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4281
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4278
Anyone know if Ford changed the TPMS sensors for 2025.
I can read all the TPS, no problem with TPMS tool.
‘The truck can’t seem to read them .
‘Plus my TPMS tool can’t read the OEM set I just took off.
Seems something may have changed.
Well just got back from the tire shop , it wasn’t my Autel TPMS tool, Ford has changed the sensors on we think the late 25 models .
Mine was build mid August and came off a Transport this week.
While some parts lookup websites show the same part number for TPMS on the 24’s and 25s.
‘There is a newer number and apparently it is not backwards compatible.
So TPMS sensors is something I can add to my list of changes 24 to 25.
Here is some others I discovered last night once I had them in garage side by side.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4283
The 12v plug in the bed is gone. Only the 110v plug is in the 25 models.
2024 model.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4285
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4284
2025 model.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4286
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4287
Also a very minor note on the steering wheel.
Notice the labeling on the buttons on the bottom of the right hand spoke.
2024 model.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4288
2025 model.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4289
There was also something I noticed using the adaptive cruise on the trip home.
‘The way it displace you distance setting is different in the 2025.
I will try and grab a pic of that later today when I go on another little trip back to my home town for some window tint this afternoon.
A.R.E Topper and BedRug is ordered.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. 1758573928293-fi
Ford Rubber Mat came in today.
Planning to use that as more of rubber floor mat sort of thing on top of the BedRug.
Since running into that TPMS issue where Ford seems to have made a late change in TPMS sensors, apparently such a recent change my Vin number still shows using the same TPMS part number I have the Bronco SAS wheels and tires I put on the 25 model when I got home Friday night.
Apparently the easiest way to make sure we get the correct sensors is going to be to rob the sensors out of the wheels it came with. Since I am going to have to dismount the 34 Yokahoma tires to do that, and having driven it about 5 hours with the 34“ 10 ply Yokahoma tires on Saturday, I was reminded why I took them off the 24 model RR. They are a little noisy, and really hurt the fuel mileage quite a bit. Plus they rub on my crash bars whenever backing up with the steering cranked.
So I did order the same tires I am running on the 24 model now, for the 2025 as well.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_5803
I ordered fir the 25 and running the stock size P285/70R17 SL load range. Much lighter, quieter, slightly smoother riding tire that by its spec and personal experience with it at this point, it’s the widest 285 I could find, it’s really pretty much the same real tread width as the 295 Yokahoma, yet it’s a 33 like came on the truck, which fixes the rub issue. It’s about an inch wider then the OEM BFGs version of the same 285/70R17 size tires.
Here is the AT4Ws on my 24 model.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. 62630-48900f2f36362d303ff2595abd79c324
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. 62632-edd6e146d24d1b564a774e812d8a2dd5
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_5805
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_5804
Tires came in , got them installed tonight.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4346
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4347
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4348
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4349
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4350
New F150Led Raptor grill marker lights came in today as well.
‘Have started the install on them yet.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_4355
Ordered some headlight surround Guards.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_5809
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_5807
I have what looks to be identical on my 24 model Ranger Raptor.
But unfortunately I paid a heck of a lot more for that set.
They look like the exact same part. Granted I thought they seemed way over priced for what they were, and wasn’t going to order them again for the 25 model, but since I found what appears to be the identical part for under $100 bucks, I decided I would go with adding them to the 25.
Ford Ranger New 2025 Ranger Raptor 2.0 (my second RR) Build. IMG_5808
