Ranger recall
Pete6114
Ontario Canada
24S64 Ford is recalling 2,416 of its 2024 Ranger and 2024-2025 Bronco vehicles. In the NHTSA report the automobile manufacturer said “the front upper control arm ball joint nut may not have been installed or tightened properly (which allows) the front upper control arm to detach from the knuckle assembly.” A detached control arm can cause a loss of vehicle steering and control. This issue will increase the risk of a crash, the report said. Recall notification letters are expected to be sent by Oct. 28
UPDATE: Just found out from my Dealer that this is not for the Ranger Raptor, Just the Ranger and Bronco
I got the recall but mine doesn't fall in the dates for it
Stu x 4
Stu
Had appointment on Monday for recall.
1st part of recall was for inspection, then if needed upper control arm to be replace if needed.
Mine turned out to be just an inspection and was on my way - no repairs!
