Rek Gen Mud Flaps
Sauce
Northeast
2025 Ranger XLT FX4
Just installed the Rek Gen Trophy Sport Universal Mud Flaps. Definitely some modification involved but all pretty straightforward and I’m happy with how they turned out. I’m going to further modify them but 95% there. These are +25 offset wheels so I was getting a lot of splashing up the sides of the truck. Hopefully this helps keep things cleaner. Most of the mud flaps like the Ford and Musology didn’t come up as high as I wanted.
a few comments on the install.
1. Rek Gen assured me none of their flaps would fit the truck, but i took a chance with these and they worked fine. I would have preferred the Baja flaps and now that I’ve installed mine I’m pretty sure I could have gotten the Baja flaps to work (it may have actually been easier to fit them)
2. Test fit the flaps first and figure out how you want them to fit. Mark them and Then use a saw or dremel to trim the excess material BEFORE they are on the truck. I trimmed one on the truck and it made things 100x more difficult than it needed to be. If you have crash bars they will be in the way, so cut the flaps around the crash bars otherwise the flaps might rub tires or limit clearance
3. The clamp style brackets that come with the flaps are terrible. The engineering of them doesn’t make any sense. Throw them out. It also comes with U bracket clips that are much better but it doesn’t come with enough of them. I ordered more and will reinstall the back flaps with these where I originally used the crap brackets.
4. Use the U bracket clips aligned with the existing holes for the fender flares which are held by plastic clips that can be discarded.
5. For the back flaps I also drilled through the plastic wheel liner and added bolts through those. The front liners aren’t plastic so you can’t do that in front and need to rely on the exiting holes.
6. To drill holes in the flaps and align them with the existing fender flares holes I created a paper template on the truck and then laid it on top of the flaps to drill. Primitive but it worked.
hopefully this helps.
Ford Ranger Rek Gen Mud Flaps IMG_1071
Ford Ranger Rek Gen Mud Flaps IMG_1069
Ford Ranger Rek Gen Mud Flaps IMG_1067
Ford Ranger Rek Gen Mud Flaps IMG_1068
Ford Ranger Rek Gen Mud Flaps IMG_1070
itsmesn00ks
Jake
2025 ranger xlt
Could you post more close ups of how you installed? You could even PM them to me. Im getting ready to buy some and want to see exactly what im getting myself into.
Sauce
Sauce
Northeast
2025 Ranger XLT FX4
I can post some this weekend. If you are ordering them, have RekGen send you additional U clip brackets because you will need them.
Its a bit of a DIY project, but the result is very solid.
itsmesn00ks
Jake
2025 ranger xlt
How many more u clips? I appreciate it if you can send some pics. Ill order now so I get them before the weekend and try to get them installed!
Sauce
Sauce
Northeast
2025 Ranger XLT FX4
Im not with the vehicle now, so I can't post pictures. I think you need 8 extra clips. RekGen sent them to me separately after I asked. RIght now I have them installed without those clamps but they would make the install a lot easier.
itsmesn00ks
Jake
2025 ranger xlt
Okay cool. I will look into that when I order. Thank you for your help.
Sauce
Sauce
Northeast
2025 Ranger XLT FX4
Here’s some pics of the inside mounting (sorrry for the mud - they were doing their job!). As an update to some of my earlier posts - the clips work fine on the front flaps, but they aren’t long enough for the back flaps. The wheel trim in front is slightly smaller than in back. I mounted using the existing trim holes around the wheel arch and then drilled a couple more holes through the plastic wheel liner. For the back flaps I just used carriage bolts with washers.
Ford Ranger Rek Gen Mud Flaps IMG_2185
Ford Ranger Rek Gen Mud Flaps IMG_2186
