ADVNTURR
- Joined
- Sep 6, 2024
- Threads
- 15
- Messages
- 203
- Reaction score
- 430
- Location
- Cleveland, OH
- Vehicle(s)
- '24 Ranger XLT 2.7L, '16 VW Golf R, '11 Nissan GT-R, '05 Nissan 350Z
- Thread starter
- #1
@braupe has already posted about these tow points with a lot of good pictures here but since I've been documenting the install of the full suite of @RIVAL 4x4 skid plates on my '24 XLT non-FX4 I figured I'd add a video of the install process for these too. These tow points are almost comically stout (I think they weight more than the radiator, engine, and trans skids combined
) and should be a bit more up to the task, especially if you end up in a situation where a straight pull isn't an option.
As with most of their skid plates, the install process was fairly easy with standard tools (one of the tow point-to-mount bolts is tough to torque if you have the front air dam installed) and the instructions and parts were all well packages and labeled when they arrived. I will note that it is a good idea to chase the threads on all the parts because some of the powder coating definitely gummed up the threads a bit on a few pieces. I also recommend using some blue Loctite on all these threads to help fight against corrosion and help keep things from coming loose.
) and should be a bit more up to the task, especially if you end up in a situation where a straight pull isn't an option.As with most of their skid plates, the install process was fairly easy with standard tools (one of the tow point-to-mount bolts is tough to torque if you have the front air dam installed) and the instructions and parts were all well packages and labeled when they arrived. I will note that it is a good idea to chase the threads on all the parts because some of the powder coating definitely gummed up the threads a bit on a few pieces. I also recommend using some blue Loctite on all these threads to help fight against corrosion and help keep things from coming loose.
