S&B Cold Air Intake Install 25 2.3l
GritzNGravy
Andrew
PNW
2025 Ranger XL 4x4
Mechanic
S&B recently released a cold air intake for the 25-26 2.3l engine. I thought why not and purchased one and received it yesterday. I installed it today, but have not had any time to drive it. The install was easy and went smooth and the instructions and video on their website is decent. Things I noticed during the install is that removing the washer filler neck makes it a lot easier and much more room and its only two 10mm bolts. The hardest thing for me was making sure the pegs on the bottom of the air box went into the factory grommets but like I said removing the washer fill neck made this easier. The wiring harness is a little tight too plug the MAF sensor but not bad, although I would like a little more slack in the harness after its connected. I didn't put the air filter in the air box before I installed it on the car and I had to remove whole thing to get the filter attached to the intake tube so do this before you install the air box to truck. The only thing is that the coolant line from the reservoir attached to the factory air box and the instruction say to attach it to the new air box, but their is no hole for the christmas tree clip to fit onto the new air box. I'm not sure if I have to drill the hole for the clip but I emailed S&B to see what they have to say.
Ford Ranger S&B Cold Air Intake Install 25 2.3l IMG_0604
Ford Ranger S&B Cold Air Intake Install 25 2.3l IMG_0606
Ford Ranger S&B Cold Air Intake Install 25 2.3l IMG_0607
Ford Ranger S&B Cold Air Intake Install 25 2.3l IMG_0603
Ford Ranger S&B Cold Air Intake Install 25 2.3l IMG_0605
