AdventureLab
- First Name
- Brit
- Joined
- Mar 14, 2025
- Threads
- 53
- Messages
- 889
- Reaction score
- 1,290
- Location
- St George, UT
- Vehicle(s)
- '24 RR
- Thread starter
- #1
Welcome
American Adventure Lab
www.AmericanAdventureLab.com
Phone: 385.202.4188 | Email: [email protected] | Instagram: @americanadventurelab
https://americanadventurelab.com/product/ranger-52-slide/
One of the biggest frustrations with truck bed storage is accessing gear that's buried deep in the bed.
Whether it's a fridge, recovery equipment, tools, or camping gear, climbing into the bed every time you need something quickly becomes inconvenient—especially when the truck is loaded for a trip.
We wanted a solution that makes gear easier to access while keeping everything organized, secure, and ready for whatever the day brings.
The American Adventure Lab Ford Ranger BASE 52" Slide is designed to provide smooth, secure access to fridges, tools, recovery gear, camp equipment, and other cargo stored in the bed of your truck. Built specifically to integrate with the Ford Ranger Bed Attachment System (BASE), the slide brings your gear out to you instead of forcing you to climb into the bed to retrieve it.
Features & Benefits:
• Designed for 6th Gen Ford Ranger models
• Integrates with the Ford Ranger Bed Attachment System (BASE)
• Provides easy access to gear stored deep in the truck bed
• Ideal for fridges, tools, recovery equipment, camp gear, and cargo
• Adjustable dividers included for customizable organization
• Additional dividers available separately
• Heavy-duty construction designed for work and trail use
• 52" locking drawer slides
• Slides lock in both open and closed positions
• Lifetime manufacturer warranty on drawer slides
• Constructed from 3mm 5052 aluminum
• Optional textured black powder coat finish available
• Fully removable if your storage needs change
• Made for overlanding, work trucks, and daily-use applications
What's Included:
• Ford Ranger 52" Slide assembly
• Two adjustable dividers
• Mounting hardware
• Installation instructions
Dimensions:
External Dimensions
• Length: 1394mm (54.88")
• Width: 595mm (23.4")
• Height: 97mm (3.8")
Interior Dimensions
• Length: 1322mm
• Width: 543mm (21.3")
• Cargo surface sits approximately 39mm (1.5") above the bed floor
Installation Notes:
• Designed to install using the Ford Ranger Bed Attachment System (BASE)
• Bolt-in installation
• Uses factory mounting points
• No drilling required
• Fully removable
• BASE system sold separately
• Installation instructions included
Frequently Asked Questions
What vehicles does this fit?
The 52" Slide is designed for Ford Ranger models equipped with the American Adventure Lab Ford Ranger Bed Attachment System (BASE).
Do I need to drill any holes?
No. The slide installs using factory mounting points through the Ford Ranger Bed Attachment System.
Does the slide lock?
Yes. The slide utilizes locking drawer slides that lock in both the open and closed positions.
Are dividers included?
Yes. Two adjustable dividers are included, and additional dividers can be purchased separately.
Can I mount a fridge on the slide?
The product is intended for fridges, tools, recovery gear, and other equipment commonly used in overland and work-truck applications. Customers should verify the dimensions of their specific equipment before installation.
Do I need the BASE System?
Yes. The 52" Slide is designed to install using the Ford Ranger Bed Attachment System (BASE), which is sold separately.
What material is the slide made from?
The slide is constructed from 3mm 5052 aluminum and utilizes heavy-duty locking drawer slides.
If you're tired of crawling into the bed of your truck to reach gear, the American Adventure Lab Ford Ranger BASE 52" Slide provides a simple and organized solution that brings your equipment out to you while maintaining secure, modular storage. Whether you're running a fridge, carrying tools, or building an overland setup, the slide is designed to make everyday access easier.
We're happy to answer any questions about fitment, BASE compatibility, gear mounting, or installation.
What's Included:
• Mounting hardware
Dimensions:
External Dimensions
Interior Dimensions
• Length: 1322mm
Installation Notes:
• Fully removable
