Which Skid Plate to Install?
prmtime101
SR5
Michael
Tampa, FL
2024 Tacoma SR5 4x4
Good morning, I am looking to purchase an aluminum skid plate. I would like one that has easy access to changing oil and oil filter. Looking for suggestions. Thanks!
nurp42
TRD PreRunner
Well-known member
SoCal
'24 PreRunner
I recently added the MCX plate and really like it. Posted write-up of it here couple weeks back if you want to see it (included pics of access to both oil filter and drain plug).
Mtnbikes
TRD Off-Road Premium
Well-known member
Chris
Minnesota
2024 Toyota Tacoma TRD OR Premium
I too just installed the Miller MCX skid plate and catalytic cover. Excellent product and very well made with covered openings for oil filter and drain plug. Plus it’s made in the USA.
prmtime101
SR5
Michael
Tampa, FL
2024 Tacoma SR5 4x4
I really like my Victory 4x4 skid plate. Using a Fumoto valve will make it easier to deal with the drain plug, been using Fumoto for years. I like how it's compatible with all trim models.
Does it need a cross member bar?
I really like my Victory 4x4 skid plate. Using a Fumoto valve will make it easier to deal with the drain plug, been using Fumoto for years. I like how the Victory 4x4 is compatible with all trim models.
Would I need to buy a separate cross member if I do not have one?
Stebo19
TRD Sport Premium
Active member
So Cal
2024 Tacoma 4x4 TDR Sport Premium Pkg upgrade
I went with the Toyota TRD plate. It doesn't have oil access but gives good coverage and is easily removed.
Victory 4x4
TRD Pro
Well-known member
BASIC Sponsor
Daryl
Portage, MI
'24 TRD Pro
Fumoto works so great. I keep a hose attached to mine and just pull it down into my drain pan when I need to drain the oil. Works awesome.
Bravada
Limited
Well-known member
S.E. Texas
2024 Taco Limited i-Force Max, Overland Tailor Tuned
No crossmember is needed, another bonus.
Bravada
Limited
Well-known member
S.E. Texas
Now that I've done my first oil change I have a question for you. My Fumoto drain hose connector is brass, and as I was reinstalling my Victory 4x4 skid plate, the drain hose adaptor popped off the drain valve. Is there a secret to keeping the drain hose adaptor on the valve?
Nacho TacoMan
Limited
Active member
Paul
2025 Tacoma Limited. 2018 BMW X5 335d
Which Fumoto drain valve are you guys using? I also like the Victory skid plate because of the straight bolt on no other cross bar needed bonus.
Bravada
Limited
Well-known member
S.E. Texas
That said, the F133N is also a solid choice. Admittedly, with a do over, I would go with the F133N. It's recessed enough to not need the adjustability.
oxi
TRD Sport
Well-known member
Pete
Wisconsin
2024 TRD Sport 6MT
I have the Victory skid plate on my TRD Sport 6MT. Dealer did 2 oil changes, nothing had to be removed except the filter access port.
No cross member needed, and factory retrieval points can be used.
Bravada
Limited
Well-known member
S.E. Texas
Go team Victory 4x4!
