Wider 33 inch tire on stock wheels?
Nikki_krause
Nikki
Anyone know the standard offset of the 33 inch ko3s from the ranger raptor?. Are they a 10.5 or…? I would like to keep 33s on the truck but want a little bit of a wider tire on the same oem headlock capable wheels. Has anyone run a wider 33 on the stock wheels??
Catalyst
Justin
Bend, OR USA
Network Engineer
Stock beadlock capable wheels are 17x8.5 +55 and the KO3 tires are 285/70R17 size. According to BFG's site they are 32.76" diameter and 11.5" section width. Actual tread width is 8.8". I'd check clearance between the inner sidewall and suspension components before going wider myself, but IIRC I've seen 12.5" wide tires on some OE RR wheels on this site. Dig around the Wheel and Tires section here for some example posts. Most people go to the Bronco SAS beadlock capable wheel that is a +30 for a bit more clearance if they want the same look/functionality.
