Would you change /cancel your Scout order?
Ajangel
Terra Harvester
Andres
Miami
Vehicles
Ram 1500
After seen Jay Leno interview yesterday and hearing about some of the new specs (Towing capability) got me thinking. I've got a Terra REEV on order, but now I'm wondering if I should just go full BEV.
Basically, anyone else watching that and thinking about switching their order? What's making you lean one way or the other? Towing? Range? Share your thoughts.
Ajangel
Ajangel
Terra Harvester
Andres
Miami
Vehicles
Ram 1500
I’m very disappointed in the reduced towing capacity and the reduced ev mileage estimate on the erev version.
I understand. Are you thinking about changing your reservation?
Red Scout
Terra Harvester
Adam
Sarasota
Vehicles
2023 Kia Carnival, 2014 Nissan Rogue
What new info was there? As far as I can tell all of that info was already known. I am still in for the harvester. The 150 miles of Eclectic range should be enough for most of my driving, but having the back up plan makes so much sense..... Added Edit... I don't plan on Towing anything.
MidpackMTB
Terra Harvester
Drew
Sacramento, CA
Vehicles
F150 Lightning, Mini Cooper
I reserved a Terra Harvester but recently traded my gas F150 in for a Lightning standard range. As I'm adapting to EV life, I'm open to changing my reservation. Still leaning EREV, but more on the fence after Jay's interview.
banjo5
Terra Harvester
Chad
Vehicles
2020 Ford F250
That was exactly my thinking as well. That Jay Leno interview provided some perspective and info I didn't previously know. I reserved the Terra extended range but after watching that I changed my reservation to be the Terra full BEV. I did not want to be limited to 5k lbs for towing and performance even if the range is further. Also, the performance, towing and advertised range make the Terra BEV a better option for me. If the towing would have not been affected so much I may have stuck with the hybrid but for now I've moved to the BEV. I realize that my towing distance will be greatly affected with the BEV but that is something I will work around with my other truck if my towing distance needs to be extended. The plus side is that the BEV will have less maintenance to worry about without the 4 cyl engine to maintain. It is a tough decision either way and I really wanted to like the extended range. There is still time for the production specs to potentially change my mind back I guess so keeping an open mind.
volsdoc81tx
Traveler Harvester
Joseph
Southlake, Texas
Vehicles
Tahoe, deposit for traveler
Not sure at this point. I had planned on using the Traveler Harvester to tow my boat. Usually not very far. The 7,000 lb initial tow weight was perfect. The new 5,000 weight limit is inadequate.
The original info was 350 battery with harvester motor adding 150 additional miles. Now it is actually the opposite.
Right now, I am not sure what to do.
Ajangel
Ajangel
Terra Harvester
Andres
Miami
Vehicles
Ram 1500
I think the same way. I also changed my reservation to BEV.
Latrant
Traveler Harvester
BC
Cleveland
Vehicles
PHEV
I may change or cancel for a RAM Charger.
slots
Terra Harvester
Doug
Wyoming, USA
Vehicles
Jeep, Subaru
From Scout Support:
Tavis • 1m ago
The Scout Terra truck, which includes the EREV model, offers a towing capacity of over 10,000 pounds, making it suitable for heavy-duty tasks in areas like Wyoming . This capability is complemented by its nearly 2,000 pounds of payload, allowing for substantial load carrying
volsdoc81tx
Traveler Harvester
Joseph
Southlake, Texas
Vehicles
From Scout Support:
Tavis • 1m ago
What about the Traveler EREV?
PMurphy
Traveler EV
Patrick
Wisconsin
Vehicles
Jeep Gladiator diesel, Ram TRX/1500 diesel
I have a Traveler EV reservation and plan to sit tight until I can actually drive/ride in a Harvester (either). Interested in how the gas engine changes ride/noise/vibration/
harshness of the vehicle. Also how/when engine kicks in for charging on the move. Can live with EV range of 275 mi (time to look for juice about then). I see Ram just announced 690 mi for Ram Charger (likely bigger battery/pony motor for gen) BUT bigger/heavier truck:
https://apple.news/AkvIN4JPBRv6BDEgi8ZW7Rg
We will all have to make our final decision at some point but now I’d keep my place in line (refundable).
Ajangel
Ajangel
Terra Harvester
Andres
Miami
Vehicles
Ram 1500
From Scout Support:
Tavis • 1m ago
So, does that mean that the 5,000LB comment was a mistake?
Macallan 18
Traveler Harvester
Jim
TN <> MI
Vehicles
2021 Jeep Gladiator Rubicon
If it was, I think Scout would have made an official comment / correction about it already. The 5K payload capacity mentioned in the episode has gotten a lot of attention online and Scout must know that.
