MandRonline
Gold Sponsor
Jesse
Burbank, CA
Ford ranger raptor
operation overseer
*** Don’t Forget: Forum Members Receive a 10% DISCOUNT!!! Use Coupon Code RANGER6G ***
Hey guys,
We’ve upgraded our website and now it’s even easier to upgrade your Ranger's lighting. One of our most popular light bar kits is the M&R 2024+ Ford Ranger 30in Light Bar PRO.
This kit is super easy to install:
1) No drilling. Complete bolt-on.
2) You do need to remove the grille but we provide step by step video instructions for an easy DIY install
3) Lifetime warranty
4) Can tap directly into your AUX switches if equipped. If not we have a perfect solution (M&R Wireless Harness)
Ford Ranger M&R Automotive 2024+ Ford Ranger 30in Light Bar PRO 2Z1A0172
Fits: 2024–2026 Ford Ranger
Trims: XL, STX, XLT, Lariat. This light bar only fits Ford Ranger trims without front grille camera
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
  • Doesn't interfere with radiator air flow
  • Don't need to fully remove grille
Choose light output color:
Each PRO bar is dual-color — a main beam plus a soft amber DRL (daytime running light) backglow.
Option 1 — White + Amber DRL
  • White LED — Super bright, crisp white beam with plenty of light for any adventure. Off-road use only — it blinds oncoming traffic and isn't street-legal.
  • Amber DRL — Purely cosmetic amber glow. Street-safe — gives off little light and won't blind oncoming traffic, so you can run it on the road.
Option 2 — Yellow + Amber DRL
  • Yellow LED — Cuts through dust, fog, snow, and rain better than white light. Ideal for poor driving conditions. Off-road use only.
  • Amber DRL — Same cosmetic amber glow. Street-safe — won't blind oncoming traffic.
  • Combo Pattern: combined spot and driving optics offer a balance between distance and width
  • Uses a TIR (Total Internal Reflection) lens, which is different from our regular slim light bar. The TIR lens collects all of the light from the LED and directly leads them to where you need, drastically reducing glare and improving total efficiency.
  • Higher light efficiency: brighter, longer irradiation distance
  • Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to protect against UV, salt water, corrosion, fading and scratch resistant.
  • Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
Ford Ranger M&R Automotive 2024+ Ford Ranger 30in Light Bar PRO 1f44d
Our light kits are for off-road use only.
For More information on the M&R 2024+ Ford Ranger 30in Light Bar PRO, click HERE
Ford Ranger M&R Automotive 2024+ Ford Ranger 30in Light Bar PRO 2Z1A0170
If you’ve bought one, post your pics and let us know what you thought! We appreciate your feedback!
MandRonline
MandRonline
Gold Sponsor
Jesse
Burbank, CA
Ford ranger raptor
operation overseer
gonzo117
Bob G
Roseville, California
2025 Ford Ranger Lariat FX4 2.7L
Network Engineer
They look like quality products. Will you be making a front light bar that will work with the front grill camera for the 2025 Ranger Lariat FX4? I don't think I've ever seen a 2024-2025 lariat without a front grill camera. Thanks
MandRonline
MandRonline
Gold Sponsor
Jesse
Burbank, CA
Ford ranger raptor
operation overseer
MandRonline
MandRonline
Gold Sponsor
Jesse
Burbank, CA
Ford ranger raptor
operation overseer
Thanks for the compliment, we believe our products are top-notch. As far as your question, we’re actively searching for Ranger with camera for prototyping. If you ever happen to be in Southern Cal, let us know.
