Ambient Lighting Stopped Working
RaptorDJD
D
South FL
2025 Ranger Raptor, 2014 Frontier Pro4X
Hello, I just noticed last night on my 2025 Ranger Raptor, the ambient lighting was not working. I went into settings and saw the toggle switch is set to on with the level at max. I toggled the switch several time but it still is not working. Everythng else appers to be operational. Any ideas?
Max 57
matt
willington ct
24 ranger 2.7 lariat
mine stopped working I hit the reset button below all is good now
RaptorDJD
D
South FL
Max 57, thanks for your reply. I did try that a couple times and even turned off the igintion with no such luck. Other than disconnecting the battery, I am out of ideas.
RaptorDJD
D
South FL
Well I figured I would provide an update in case anyone else has this issue. After a complete and total reset of sync and disconnecting the negative battery terminal, the problem is gone and everything is working again. Go figure.
