RR R Button stopped working - Easy fix!
jrRaptor
Maize, KS
Mine has done it quite a few times, maybe about 8 or 9 times now. But I haven't seen it happen in several months (knock on wood). However, I did have my driver's door switch panel stop working - no window, lock, or mirror control and no switch illumination. Other door switches worked fine and illuminated normally. Restart didn't fix it but disconnecting the battery did. Sometimes I feel like I bought a jeep. ?
Your not alone with the odd electronic glitches and what not.
Was back at my Ford Dealer this morning getting the second TPS sensor in months time replaced under warranty. Seems they are going bad one at time so I get to spend a couple hours in the waiting area of the service department every couple weeks. I asked today why not change the other 2 while I was there, and said they had to wait for them to fail before warranty would cover them. LOL
I have a trailer profile programmed into my truck to compensate for my lighted headache rack.
The redundant lighting in the rack trips the auto trailer detection and if you don't program in the parameters it disables the blind side monitors among other things. At least once a month it forgets the trailer profile I have programed into it and I have re-initiate it to get my safety features working again. Apparently there is not any way to shut off abut trailer detections, so I just deal with it.
I do actually like my electronic driver aids when they work that is. LOL
I just wish Ford would make some improvements to reliability and function of these systems.
jburl2
Jim
24 Ranger Raptor 07 Sport Trac
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
My RR Raptor Mode has failed twice. Fixed with Battery disconnect. Vin 1FTR4LR8RLE55719.
Have an appointment Thursday with Tasca Ford to try to resolve. Please look into this...
Hoss
Dale
Gainesville, Georgia
Wizard
Ok i will
jrRaptor
Maize, KS
They stopped replying and do not actively monitor this forum anymore. They posted as such on Dec 30, 2024.
RaptorBaby23
24 RR
Yep disconnected the neg cable, did the trick.. for now anyway.
Any social way to disconnect the neg battery terminal? Mine looks to have a lot of wiring going on and not just a plain battery terminal?
jrRaptor
Maize, KS
10mm socket or wrench. Just loosen the nut and pull off the battery post. I keep one of those short stubby 10mm ratchet wrenched in the center console just for that.
