Battery issue / charging
tmuecke
Tom
Spain
Ranger Wildtrak X 2024
Hi
I just realised that my one year old Ranger doesn’t do start/stop saying he needs to charge. The battery is a Ford AGM 80AH 800A, manufactured by Johnson Controls.
From time to time I got a message telling me that the car went to power saving mode. Even after extended use.
I charged the battery with an external charger and did some tests. The cranking health seems to be ok, but max charge ist only around 80%.
Fully charged (says the charger) voltage is still only around 12.5v, and the in use voltage drops to around 11.9V. The alternator delivers 14.4V.
Some questions:
1. I read that Ford has - for environmental reason - programmed the max SOC to 80%. Can somebody confirm this? Means without external charger you’ll never get 100%?
2. What voltage do one measure on a charged battery? Shouldn’t it be more than 12.5v. How much would you have after one night in the morning?
3. Can I swap the battery without reprogramming the BMS? If not what parameters does the BMS need?
4. How can I prevent this issue for the future with a new battery?
4. Is there any other software than FORScan to programm the BMS, compatible with MacOs or better on iOS?
Thanks for sharing your help!
Don Vandyke
Don
Auburn Hills, Michigan
Ford Vandyke
Ford has a battery problem here in the US. It should be under warranty. Don't know how things work in Spain but your dealer should replace, no charge
