Elfman
- Joined
- Nov 18, 2024
- Threads
- 4
- Messages
- 28
- Reaction score
- 13
- Location
- California
- Vehicle(s)
- 2003 Honda Civic
- Thread starter
- #1
Excellent condition Diamondback 180 "butterfly wing" hard bed cover. If you don't know: all aluminum construction, rugged black "diamond plate" exterior finish, haul capacity is 400 pounds, both "wings" open from the bed side of the truck and stay open with dashpot dampers, and have key-locking latches on each wing door and weather stripping all around. These are very sturdy covers, and I liked the 180 bedside access rather than the fore and aft access, which seemed weird trying to access something against the back window. All the installation and accessories instructions are included, as well as two t-slot tool bars that mount under each wing (one is installed already, the other is uninstalled in the photos). One of the wings also has the accessory LED light bar installed, and I also installed the accessory external cleats (four, one at each corner). I also separately installed two larger t-slot rails on the top on each side, with weather tight seals under each bolt. All mounting hardware and keys included. You will need to get the bulkhead rail, bulkhead weather stripping, and the rivnuts, since you won't want mine from my truck when it was installed, you'll want new ones. But other than that, this is turn-key and ready to install and in great shape. I just decided to go a different direction and left the bed open. My experiment is your gain, I'm willing to let this go for $1500 (cover alone is $2399 new, plus about $400-500 in accessories here). I'm in the Bay Area of California. I do travel occasionally in the Bay Area and Central Coast and could deliver if its not too far out of my way and I happen to be traveling for work.
