Disc brake replacement
joordan
Italy
ranger wildtrak 2023
Just to be sure..discs are in place only by the wheel tyre screws right?I cannot see any small countersunk screw that fix the disc as most cars has..
so I assume once removed the wheel and the brake caliper, a good hammer will do the job in displacing the disc from the rust and get it off do replacement
talking rear discs
Depotgeorge
George
Nj
24 ranger
Yup no rotor set screw on the rears. Wheels, pads, Caliper bracket, and tap rotor off
Depotgeorge
George
Nj
24 ranger
I could not but brakes in service mode via key gas pedal key on/off sequence. I just did it through forscan. Also caliper on rear are a clockwise/tighten to retract pads.
