Forscan Settings Ranger Raptor Specific
tony1985
Anthony
Greece
Hello, wasn't sure which section to post this since there is no software option, I guess this is as good as any.
I wanted to make some Forscan changes to my RR for some time however the spreadsheet posted somewhere in the general forum was only for NA and some stuff doesnt work for us EU folk, some stuff dont apply to the Raptor and most of my annoyances / stuff I wanted to change were not covered or were not confirmed.
So I am sharing the stuff that I did below, to help out (also have a question at the end):
Disable seatbelt ok graphic (only) - not the chime:
IPC -> 720-13-01 -> change XXXX XXXX XXXX to 0000 0000 0000
Enable Auto Lock at speed (menu option on infotainment):
BCM (not asbuilt) -> change Autolock initial Value from INOPERATIVE to ENABLED, Autolock Personal (1 through 4) from INOPERATIVE to DISABLED, Autolock Vehicle from INOPERATIVE to DISABLED
APIM (not asbuilt) -> Autolock control function from DISABLED to ENABLED
Have DRLs at 75% brightness with Low beams (I have the amber DRL by signature LUX and at the default 10% when the headligths are on, looks bad - especially with the marker lights being so much brighter:
BCM -> 726-38-01 -> change XXXX 0AXX XXXX to XXXX 3CXX XXXX
Lane keep assist (remember last state):
IPMA -> 706-02-01 -> change XXXX XXXX X3XX to XXXX XXXX X1XX
Permanently disable reverse brake assist:
APIM (not asbuilt) -> Reverse brake assist from ENABLED to DISABLED
Disable chime when over speed limit:
IPC (not asbuilt) -> Inteligent speed assistance from ENABLED to DISABLED
So these are my two cents.
My question- if anyone has looked into it - is the following: In the EU version, we have the Glare-Free function of the auto high beams enabled (boxing out oncoming cars with the matrix headlights). In my experience the auto high beams rarely turn on and get turned off at even the slightest indication of a street light, far away car or even light reflections off of parked cars. I have looked into the matter a bit and turns out the cars have two settings for the sensitivity of when the high beams come on or turn off: These are a minimum speed activation threshold(default is 40km/h or 25mph) which i want to turn down to 15km/h and a minimum Lux activation threshold (light sensitivity) which i want to significantly lower. Has anybody tinkered with these settings?
Thanks!
ag02m5
Google
Good to know on the DRL. Sitting on the shelf waiting for install.
