That is wheel travel.Im not sire about the actual shock lengths but stock shocks have 10” and 11.5” travel for front and rear, respectively.
While I know that the "travel" will only provide the delta between full compression and extension, not the actual length of the shocks, I put those up as a FYI.That is wheel travel.
Not shock travel.
One has almost nothing to do with the other…
That’s referred to as shock “stroke”.While I know that the "travel" will only provide the delta between full compression and extension, not the actual length of the shocks, I put those up as a FYI.
BTW, shock travel length is directly correlated to wheel travel length via Motion Ratio. In Toyota IFS, it was roughly 1:2. I'm pretty sure it'll be similar for the Ford IFS.
