Catalyst
- First Name
- Justin
- Joined
- Mar 27, 2024
- Threads
- 1
- Messages
- 466
- Reaction score
- 611
- Location
- Bend, OR USA
- Vehicle(s)
- 2024 Ranger Raptor
- Occupation
- Network Engineer
- Thread starter
- #1
For Sale $550 $500 Shipped Continental USA
BNIB (never opened)
Wagner Tuning Intercooler for Ranger Raptor.
I’ve changed directions for my RR and you can save here! Less than what I paid during early purchase sale. Ships promptly with tracking in manufacturer packaging.
actual photos per requirements and a few stock images of what is inside.
Description from Wagner:
Wagner Tuning Intercooler for Ford Ranger Raptor 3.0 V6 69% more volume & performance kit
Unleash the full power of your Ford Ranger Raptor! With the state-of-the-art Wagner Tuning Performance Intercooler Kit, you can take your Ford Ranger Raptor 3.0 V6 to a whole new level of performance. This upgrade is the ideal solution for eliminating OEM bottlenecks, dramatically improving cooling performance, and achieving a massive increase in power. Experience the unmatched power that lies within your Raptor.
Why this intercooler is the best choice for your Ranger Raptor:
69% more volume: With impressive core dimensions of 550 mm x 300 mm x 110 mm, our intercooler offers a sensational volume of 11 liters. That's an incredible 69% increase over the standard cooler (6.5 liters). The result: significantly more air, more power, and a noticeable increase in performance.
Outstanding cooling performance & 33% larger flow area: The stunning 33% larger flow area (1080 cm² vs. OEM 810 cm²) ensures maximum heat transfer. The precisely engineered cast aluminum end boxes and the custom intercooler core configuration with internal turbulators have been carefully designed to ensure ideal airflow and highly efficient heat transfer. This provides exceptionally good cooling properties with low pressure loss.
Optimized design and durability: The intercooler is designed to withstand the toughest off-road conditions. A high-quality anti-corrosion protective coating protects against environmental influences and guarantees long-lasting, optimal cooling performance that is designed for a long service life.
Easy plug-and-play installation: Installation is quick and easy at the original mounting points thanks to the plug-and-play principle. You can simply replace the standard intercooler with our high-performance model. Get ready to experience performance like never before!
Technical details & vehicle compatibility:
Wagner Tuning Performance intercooler:
Net dimensions: 550 mm x 300 mm x 110 mm
Net volume: 11 liters (+69% vs. OEM 6.5 L)
Flow area: 1080 cm² (+33% vs. OEM 810 cm²)
Installation: 100% plug-and-play
Suitable for:
Ford Ranger Raptor 215 kW/292 hp (from 11/2022) 3.0 V6 EcoBoost 4WD
BNIB (never opened)
Suitable for:
